July 28, 2018, 15:34 |
mpirun stops
Bill Lasher
Rep Power: 16 |
Hi:
I just bought a 20-core workstation and occasionally my job will stop with the following message: [1]+ Exit 65 mpirun -np 20 twoPhaseEulerFoam -parallel > log I'll get the same message with other numbers of processors. The log file seems to be fine, and if I simply restart the job it will run ok. I don't see anything else unusual on the console. Any idea what this means? Thanks |
July 29, 2018, 02:14 |
Vivek
Rep Power: 8 |
Have you divided your solution domain into 20 sub domains?
If not Use decomposePar command after that run mpirun -np 20 ....etc |
July 29, 2018, 11:51 |
Bill Lasher
Rep Power: 16 |
Hi:
Yes, I did subdivide the domain. It runs fine most of the time, just stops for no apparent reason occasionally. If I just restart it it works fine, so I don't think the problem is with OpenFOAM - I think it's either an MPI problem or perhaps a hardware problem. Bill |
July 30, 2018, 20:01 |
Peter Baskovich
Rep Power: 11 |
I think you have an issue with the environment setup. Are you using the MPI that came with OF?
July 31, 2018, 11:23 |
Bill Lasher
Rep Power: 16 |
Hi Peter:
The MPI environment variable WM_MPLIB is set to SYSTEMOPENMPI. This is set in /opt/openfoam6/etc/bashrc. Notice that mpirun usually works, it just ends sometimes for no apparent reason. Bill |
what is wrong with the mpirun parameter -mca ? | donno | OpenFOAM | 7 | February 2, 2023 21:12 |
MPIrun Problem with FoamJob Workaround | kaszt | OpenFOAM Running, Solving & CFD | 3 | October 4, 2018 12:55 |
Simulation stops at simulation but doesn't diverge mpirun error | Dar87 | OpenFOAM Running, Solving & CFD | 0 | March 28, 2018 03:52 |
mpirun unable to find SU2_PRT | Apollinaris | SU2 Installation | 1 | May 10, 2017 05:31 |
using mpirun | EmadTandis | OpenFOAM Running, Solving & CFD | 1 | December 4, 2016 14:29 |
