July 30, 2018, 11:30 |
MULES or GAMG error, hull in waves
tommaso acerbi
Hi all,
I am running URANS simulations, interdymfoam solver in OF5.0, to evaluate wave impact loads on a yacht sailing both in upright conditions and with an heeling angle. Before implementing waves, I run a simil-steadystate simulation, fixed geometry with interfoam, to develop the flow around the hull and obtain a stable solution. After that I switch to interdymfoam, release pitch, heave, roll and yaw two at a time and again run until I obtain again a stable solution. The two cases have exactly the same set up except for the mesh, however, while the upright case runs with no problems, the heeled one gives a lot of troubles. The domain is built with two adjacent inlets and two adjacent outlets because I saw this is the best way I can simulate oblique waves. To model turbulence I use k-omega SST. Since the upright case runs with no problems in waves, I believe that the problem is not in the boundary or initial conditions, but is a matter of mesh quality and linear solvers. The simulations crash giving the following error Code:
Courant Number mean: 0.000203452 max: 4652.73 Interface Courant Number mean: 3.34743e-05 max: 4652.73 deltaT = 8.8832e-09 Time = 145.747 PIMPLE: iteration 1 forces forces: Not including porosity effects Restraint heelingAngle: angle 0.418438 moment (1.17675e+06 0 0) Restraint heading: angle 0.0017102 moment (0 0 -171020) 6-DoF rigid body motion Centre of rotation: (-17.53 0 1.04225) Centre of mass: (-17.53 0 1.04225) Orientation: (0.999727 -0.00156266 -0.0232849 -0.00803394 0.913724 -0.406256 0.0219108 0.406334 0.913463) Linear velocity: (0 0 0.935723) Angular velocity: (-0.0433544 -0.184461 0.301831) Execution time for mesh.update() = 0.99 s smoothSolver: Solving for alpha.water, Initial residual = 1.83736e-09, Final residual = 3.84139e-13, No Iterations 4 Phase-1 volume fraction = 0.777394 Min(alpha.water) = -0.00342231 Max(alpha.water) = 1.00001 Applying the previous iteration compression flux MULES: Correcting alpha.water MULES: Correcting alpha.water MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.777394 Min(alpha.water) = -0.00307888 Max(alpha.water) = 1.00001 smoothSolver: Solving for alpha.water, Initial residual = 1.71623e-09, Final residual = 2.13096e-13, No Iterations 4 Phase-1 volume fraction = 0.777394 Min(alpha.water) = -0.000831378 Max(alpha.water) = 1.00001 Applying the previous iteration compression flux MULES: Correcting alpha.water MULES: Correcting alpha.water MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.777394 Min(alpha.water) = -0.00057803 Max(alpha.water) = 1.00001 GAMG: Solving for p_rgh, Initial residual = 0.720243, Final residual = 2.90107e+78, No Iterations 1000 time step continuity errors : sum local = 3.03974e+71, global = 6.9005e+67, cumulative = 6.9005e+67 [3] #0 [2] Foam::error::printStack(Foam::Ostream&)#0 Foam::error::printStack(Foam::Ostream&) at ??:? [3] #1 Foam::sigFpe::sigHandler(int) at ??:? [2] #1 Foam::sigFpe::sigHandler(int) at ??:? [3] #2 ? at ??:? [2] #2 ? in "/lib64/libpthread.so.0" [2] #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/lib64/libpthread.so.0" [3] #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:? [2] #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? [3] #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? [2] #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? [3] #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? [2] #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? [3] #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? [2] #7 at ??:? [3] #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&)Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? [2] #8 at ??:? [3] #8 ?? at ??:? [2] #9 __libc_start_main at ??:? [3] #9 __libc_start_main in "/lib64/libc.so.6" [3] #10 in "/lib64/libc.so.6" [2] #10 ?? at ??:? at ??:? Given that, I created a completely new (better) mesh for the heeled case and rerun the fixed hull case first. Again this first step runs smoothly, however when I switch solver and release the first two degrees of freedom (pitch and heave) it stops again with a sudden MULES error, as in the attachment interDyMFoam.c, or a GAMG error as the previously posted. at the link https://1drv.ms/f/s!As9yywBJJOyYpQDp9ieKkZhPs2zs I uploaded folders with the two cases (heel_waves with the GAMG error, and heel_dynamic with the refined mesh and MULES error), complete with all the dictionaries and logs, so that if someone is interested and has time it is possible to give it a look and maybe get back with suggestions. I cannot upload the .stl files due to confidentiality, but if needed I can upload pictures of the mesh. Please let me know if I missed something in the description of the problem Regards, Tommaso |
fvsolutions, gamg, interdymfoam, mules |
Suppress twoPhaseEulerFoam energy | AlmostSurelyRob | OpenFOAM Running, Solving & CFD | 33 | September 25, 2018 17:45 |
Free surface issues with interDyMFoam for hydroturbine | oumnion | OpenFOAM Running, Solving & CFD | 0 | October 6, 2017 14:05 |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 22:13 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
