August 7, 2018, 14:28 |
boudary conditions do not work
Rep Power: 7 |
Hello everyone;
i am trying to run for days this problem of an open test section of a wind tunnel and it is never working, i created my grids in pointwise and when it comes to setting my boudary conditions in openFoam i always get this continuity error #Create mesh for time = 0 PISO: Operating solver in PISO mode Reading transportProperties Reading field p Reading field U Reading/calculating face flux field phi Starting time loop Time = 0.005 Courant Number mean: 0.0123967 max: 2.45 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.00116461, No Iterations 1000 smoothSolver: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0 DICPCG: Solving for p, Initial residual = 1, Final residual = 0.0405119, No Iterations 14 time step continuity errors : sum local = 0.00391647, global = -0.000631697, cumulative = -0.000631697 DICPCG: Solving for p, Initial residual = 0.00450157, Final residual = 8.79408e-07, No Iterations 30 time step continuity errors : sum local = 7.64836e-07, global = -4.35029e-08, cumulative = -0.000631741 ExecutionTime = 0.15 s ClockTime = 0 s Time = 0.01 Courant Number mean: 0.382124 max: 25.3777 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib64/libc.so.6" #3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:? #4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<d ouble>&, Foam::Field<double> const&, unsigned char, int) const at ??:? #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 ? at ??:? #7 ? at ??:? #8 ? at ??:? #9 ? at ??:? #10 __libc_start_main in "/lib64/libc.so.6" #11 ? at ??:? Floating point exception this is my U file #internalField uniform (0 0 0); boundaryField { bd1 { type symmetryPlane; } bd2 { type symmetryPlane; } bottomendoftestsection { type fixedValue; value uniform (0 0 0); } endofshearlayer { type fixedValue; value uniform (0 0 0); } inlet { type fixedValue; value uniform (30 0 0); } outlet { type inletOutlet; value $internalField; inletValue uniform (0 0 0); } outlet1 { type fixedValue; value uniform (0 0 0); } outsidebottom1 { type fixedValue; value uniform (0 0 0); } outsidebottom2 { type fixedValue; value uniform (0 0 0); } outsidebottom3 { type fixedValue; value uniform (0 0 0); } outsideleft { type fixedValue; value uniform (0 0 0); } outsideright { type fixedValue; value uniform (0 0 0); } outside1 { type fixedValue; value uniform (0 0 0); } outside2 { type fixedValue; value uniform (0 0 0); } shearlayer { type fixedValue; value uniform (0 0 0); } walls { type noSlip; } BaseAndTop { type empty; } } and P file #dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { bd1 { type symmetryPlane; } bd2 { type symmetryPlane; } bottomendoftestsection { type totalPressure; rho rho; psi none; gamma 1; p0 uniform 0; value uniform 0; } endofshearlayer { type totalPressure; rho rho; psi none; gamma 1; p0 uniform 0; value uniform 0; } inlet { type fixedFluxPressure; value uniform 0; gradient uniform 0; } outlet { type totalPressure; rho rho; psi none; gamma 1; p0 uniform 0; value uniform 0; } outlet1 { type zeroGradient; } outsidebottom1 { type zeroGradient;; } outsidebottom2 { type zeroGradient; } outsidebottom3 { type zeroGradient; } outsideleft { type zeroGradient; } outsideright { type zeroGradient; } outside1 { type zeroGradient; } outside2 { type zeroGradient; } shearlayer { type totalPressure; rho rho; psi none; gamma 1; p0 uniform 0; value uniform 0; } walls { type zeroGradient; } BaseAndTop { type empty; } } i have so many boudary conditions because i am trying to analyze the the flow of air that is going out from the open test section and see how far the shear layer goes. i put only half of the test section assuming that is symmetric seen from the top. i can attach a picture of what i am working on. |
August 8, 2018, 03:02 |
#2 | |
Robert
Rep Power: 11 |
you can see that either your time step is too large OR your velocity to high OR your mesh size doesn't fit. Or a combination of those.
If you liked my answer to your question, please consider leaving a "Like" in return |
August 16, 2018, 12:53 |
not able to run icofoam because of to the time in controldict
Rep Power: 7 |
Thank you RobertHB for your help.
i changed from working now from poitwise to openFoam completely starting with a simple design to get familiarized with OpenFoam, so this is my new Block Mesh; vertices ( (0 0 0) (1.5 0 0) (0 0.3 0) (1.5 0.3 0)//3 (0 0.6 0) //4 (1.5 0.6 0) (0 0 0.1) //6 (1.5 0 0.1) (0 0.3 0.1) //8 (1.5 0.3 0.1) //9 (0 0.6 0.1) (1.5 0.6 0.1) //11 ); blocks ( hex (0 1 3 2 6 7 9 8) (20 20 1) simpleGrading (1 1 1) hex (2 3 5 4 8 9 11 10) (20 20 1) simpleGrading (1 1 1) ); edges ( ); boundary ( farfield { type patch; faces ( (4 10 11 5) ); } inlet { type patch; faces ( (2 8 10 4) ); } outlet { type patch; faces ( (3 5 11 9) ); } symmetry { type symmetryPlane; faces ( (0 1 7 6) ); } rightside { type patch; faces ( (0 6 8 2) ); } leftside { type patch; faces ( (1 3 9 7) ); } frontAndBack { type empty; faces ( (2 4 5 3) (0 2 3 1) (6 7 9 8) (8 9 11 10) ); } ); mergePatchPairs ( ); my problem now is that when i run icoFoam with this ControlDict it start calculating time but it stops at at certain time, i tried to calculate the courant number before but im still confused how to choose the right delta time and interval if i want the end time to be enough to see the end of what happens in the animation using paraFoam. is there another formula that gives the time steps that show up in paraFoam? or a formula between the interval and delta T? besides the courant number because i tried different times and icoFoam stops. application icoFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 0.05; deltaT 0.000005; writeControl timeStep; writeInterval 10; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; Time = 0.00961 Courant Number mean: 0.128956 max: 1.45861 smoothSolver: Solving for Ux, Initial residual = 0.0223022, Final residual = 9.80215e-06, No Iterations 27 smoothSolver: Solving for Uy, Initial residual = 0.0227496, Final residual = 9.78112e-06, No Iterations 37 DICPCG: Solving for p, Initial residual = 0.0611888, Final residual = 0.00213952, No Iterations 4 time step continuity errors : sum local = 4.34267e-05, global = -1.04824e-05, cumulative = -0.000153279 DICPCG: Solving for p, Initial residual = 0.0140375, Final residual = 9.42045e-07, No Iterations 33 time step continuity errors : sum local = 1.98796e-08, global = -6.87078e-10, cumulative = -0.00015328 ExecutionTime = 4.63 s ClockTime = 7 s Time = 0.009615 Courant Number mean: 0.136936 max: 1.51927 smoothSolver: Solving for Ux, Initial residual = 0.0243793, Final residual = 3.00823e+06, No Iterations 1000 smoothSolver: Solving for Uy, Initial residual = 0.0260771, Final residual = 2.41502e+07, No Iterations 1000 DICPCG: Solving for p, Initial residual = 1, Final residual = 0.0472285, No Iterations 23 time step continuity errors : sum local = 56726.1, global = 800.186, cumulative = 800.186 DICPCG: Solving for p, Initial residual = 0.222503, Final residual = 4.24965e-07, No Iterations 38 time step continuity errors : sum local = 4.94998, global = -0.0741813, cumulative = 800.112 ExecutionTime = 4.7 s ClockTime = 7 s Time = 0.00962 Courant Number mean: 1.35673e+07 max: 6.22719e+08 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:? #4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<d ouble>&, Foam::Field<double> const&, unsigned char, int) const at ??:? #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 ? at ??:? #7 ? at ??:? #8 ? at ??:? #9 ? at ??:? #10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #11 ? at ??:? Floating point exception (core dumped) thank you for your help. |
August 16, 2018, 14:12 |
Rep Power: 7 |
Also does the time setting in controldict depends on my entries in 0 file, pressure and velocity? because sometimes it runs and i don t get my results so i change the inputs of my outlets and it gives me an error of divergence even though usng the same time steps of last run... i am so confused! i will appreciate your help.
August 17, 2018, 02:16 |
Srikar Reddy Palla
Rep Power: 8 |
Try to decrease the 'deltaT', with info you gave... that should clear your problem.
August 17, 2018, 04:30 |
Robert
Rep Power: 11 |
Usually your velocity and mesh size are they way you need them, so to combat the Co number, you can only change the time step.
Your simulation runs from startTime to endTime and your variables are calculated every deltaT, the timestep. How often your simulation writes data to a folder is deterimed by writeControl and writeInterval. At the moment every 10th timestep = every 5e-5 sec. You could change this to writeControl runTime; writeInterval xxx; to get data every xxx seconds. Since your simulation blows up so suddenly, i'd guess its more a problem of your mesh than of your timestep. Eventhough thats still to large (Co_max > 1).
#boudary #conditions |
nonreflective boudary conditions | mfinke | CFX | 8 | December 20, 2013 17:19 |
HELP,how to define the periodic boudary conditions using the icem mesh? | dada1204 | FLUENT | 2 | May 1, 2012 17:06 |
boudary conditions for flow past a sphere | srijit goswami | Main CFD Forum | 3 | January 27, 2001 07:28 |
A problem about setting boundary conditions | lyang | Main CFD Forum | 0 | September 19, 1999 18:29 |
