simulating flow over aerofoil(naca0012)using openfoam |
zein elserfy
Rep Power: 9 ![]() |
I have tried to model flow over the aerofoil using SA model and the result for lift and drag coefficient using not matching the experimental data, then I try to use K-w SST model and I have problems in convergence espically at the angle of attack higher than 10
have anyone tried this case on openfoam? so we can share our result |
Display Modes | |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Simulating flow with known pressure drop | MrAndersDk | OpenFOAM Running, Solving & CFD | 8 | August 17, 2018 02:38 |
OpenFOAM 5.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 11 | June 5, 2018 23:48 |
A problem of incorrect fluid flow field using Openfoam | marialhm | OpenFOAM Running, Solving & CFD | 25 | June 12, 2017 02:34 |
Simulating Creeping (Stokes) Flow in OpenFOAM | shanleyk | OpenFOAM Running, Solving & CFD | 3 | July 9, 2015 15:41 |
