interPhaseChangeFoam for THREE phase
Old   October 3, 2013, 07:22
Default interPhaseChangeFoam for THREE phase
vishal
vishal_s is on a distinguished road
I am trying to simulate a flow in a different density medium. The flow gets vaporized once it reaches the specific value. Now in interPhaseChangeFoam tutorial, it is given only for 2 phases (one liquid and vapor), how to incorporate another fluid and what changes I should make in the solver. How to define the alpha1 for three fluids( 2liquids and vapor)? Do I need two alpha1 file (one for two different liquid and one for vapor, at t=0).
Please suggest
vishal_s is offline   Reply With Quote
Old   August 3, 2017, 03:20
Alice
yangzhuan is on a distinguished road
Please suggest
Hi, vishal,
I also want to simulate three phase, and two liquid and vapor. But I am newer here. I don't know how to modify the interPhaseChangeFoam. Do you have solved it?
Hope you could have time to reply! Thanks.
yangzhuan is offline   Reply With Quote
Old   August 3, 2017, 05:20
Felix
fimbull is on a distinguished road
On the one hand:
There is only the solver interPhaseChange(DyM)Foam avaiable to simulate two phase with phase-changing processes (e.g. Oil and vapour to simulate cavitation in journal bearings).
on the other hand:
There is the three-phase solver multiphaseInter(DyM)Foam, which can calculate flows consisting of three phases but without phase change .
That means:
you maybe must build your own solver based of the two solvers mentioned above.
for more informations follow the link please
https://cfd.direct/openfoam/features/multiphase/
fimbull is offline   Reply With Quote
Old   August 3, 2017, 05:42
Alice
Originally Posted by fimbull View Post
On the one hand:
on the other hand:
That means:
Hi, Felix
Firstly, thank you for your reply.
I also feel I should build my own solver. The multiphaseInterFoam includes four phase. In my case, there is two inlet(one is liquid1 and another is for liquid2), the outlet is vapor(vapor generate when two liquid meet due to difference in temperature). It is like boiling. So i think i should use interPhaseChangeFoam by adding the temperature field. But I don't know how to modify the alpha file.
Could you have any suggestion?
Best.
Old   September 1, 2018, 00:57
Ainal Hoque Gazi
A H Gazi is on a distinguished road
On the one hand:
on the other hand:
That means:
Hi
I want to model a river flow, in which there will be three layers air,water and sediment from top to bottom.Would you please suggest me which solver should i used in openfoam and where to define the layers thickness.
Thanks.
A H Gazi is offline   Reply With Quote
How to access only one phase in multiphase model by UDF wersoe Fluent UDF and Scheme Programming 1 January 4, 2017 07:11
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
VOF for single phase? vuccj7 FLUENT 0 April 20, 2011 19:59
two Phase column simulation chemeng OpenFOAM 3 August 18, 2010 12:53
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
