rhoSimpleFoam time step continuity errors
Like Tree1Likes
  • 1 Post By deepbandivadekar
Old   September 3, 2018, 11:19
Default rhoSimpleFoam time step continuity errors
Deep
deepbandivadekar is on a distinguished road
I'm trying to solve a 2 streams mixing problem for a particular geometry. SO I have 2 inlets and one outlet and the mesh is completely structured for the rectangular geometry. I am getting time step continuity errors as shown below.
Create time
Create mesh for time = 0
SIMPLE: convergence criteria
    field p     tolerance 0.01
    field U     tolerance 0.0001
    field e     tolerance 0.001
    field "(k|epsilon|omega)"     tolerance 0.001
Reading thermophysical properties
Selecting thermodynamics package
    type            hePsiThermo;
    mixture         pureMixture;
    transport       sutherland;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
Reading field U
pressureControl
    pMax 165000
    pMin 40494
Creating turbulence model
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
No MRF models present
No finite volume options present
Starting time loop
Time = 1
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.0628401, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.0397387, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 0.999999, Final residual = 0.0163076, No Iterations 4
smoothSolver:  Solving for e, Initial residual = 1, Final residual = 0.0169938, No Iterations 1
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.0314266, No Iterations 2
time step continuity errors : sum local = 4744.53, global = -3840.24, cumulative = -3840.24
ExecutionTime = 3.93 s  ClockTime = 4 s
Time = 2
smoothSolver:  Solving for Ux, Initial residual = 0.112653, Final residual = 0.00870741, No Iterations 4
smoothSolver:  Solving for Uy, Initial residual = 0.663654, Final residual = 0.011927, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 0.169241, Final residual = 0.0155358, No Iterations 4
smoothSolver:  Solving for e, Initial residual = 0.807748, Final residual = 0.00160731, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.978126, Final residual = 0.0452374, No Iterations 6
time step continuity errors : sum local = 1138.37, global = -218.941, cumulative = -4059.18
pressureControl: p max 275246
ExecutionTime = 7.25 s  ClockTime = 8 s
Time = 3
smoothSolver:  Solving for Ux, Initial residual = 0.152194, Final residual = 0.00842596, No Iterations 4
smoothSolver:  Solving for Uy, Initial residual = 0.5878, Final residual = 0.0443492, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 0.0984365, Final residual = 0.0096684, No Iterations 4
smoothSolver:  Solving for e, Initial residual = 0.313931, Final residual = 0.00362717, No Iterations 1
[mae-hen-8163-db:22471] *** Process received signal ***
[mae-hen-8163-db:22471] Signal: Floating point exception (8)
[mae-hen-8163-db:22471] Signal code:  (-6)
[mae-hen-8163-db:22471] Failing at address: 0x3e9000057c7
[mae-hen-8163-db:22468] *** Process received signal ***
[mae-hen-8163-db:22468] Signal: Floating point exception (8)
[mae-hen-8163-db:22468] Signal code:  (-6)
[mae-hen-8163-db:22468] Failing at address: 0x3e9000057c4
[mae-hen-8163-db:22468] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7fea736c4f20]
[mae-hen-8163-db:22468] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7fea736c4e97]
[mae-hen-8163-db:22468] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7fea736c4f20]
[mae-hen-8163-db:22468] [ 3] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE9calculateEv+0x305)[0x7fea7919b825]
[mae-hen-8163-db:22468] [ 4] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE7correctEv+0x2a)[0x7fea791ad87a]
[mae-hen-8163-db:22468] [ 5] rhoSimpleFoam(+0x2ae46)[0x55ae34731e46]
[mae-hen-8163-db:22468] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7fea736a7b97]
[mae-hen-8163-db:22468] [ 7] rhoSimpleFoam(+0x2f96a)[0x55ae3473696a]
[mae-hen-8163-db:22468] *** End of error message ***
[mae-hen-8163-db:22471] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f76cdac4f20]
[mae-hen-8163-db:22471] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7f76cdac4e97]
[mae-hen-8163-db:22471] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f76cdac4f20]
[mae-hen-8163-db:22471] [ 3] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE9calculateEv+0x305)[0x7f76d359b825]
[mae-hen-8163-db:22471] [ 4] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE7correctEv+0x2a)[0x7f76d35ad87a]
[mae-hen-8163-db:22471] [ 5] rhoSimpleFoam(+0x2ae46)[0x5580f29cae46]
[mae-hen-8163-db:22471] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f76cdaa7b97]
[mae-hen-8163-db:22471] [ 7] rhoSimpleFoam(+0x2f96a)[0x5580f29cf96a]
[mae-hen-8163-db:22471] *** End of error message ***
[mae-hen-8163-db:22470] *** Process received signal ***
[mae-hen-8163-db:22470] Signal: Floating point exception (8)
[mae-hen-8163-db:22470] Signal code:  (-6)
[mae-hen-8163-db:22470] Failing at address: 0x3e9000057c6
[mae-hen-8163-db:22470] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7fd153bc5f20]
[mae-hen-8163-db:22470] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7fd153bc5e97]
[mae-hen-8163-db:22470] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7fd153bc5f20]
[mae-hen-8163-db:22470] [ 3] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE9calculateEv+0x305)[0x7fd15969c825]
[mae-hen-8163-db:22470] [ 4] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE7correctEv+0x2a)[0x7fd1596ae87a]
[mae-hen-8163-db:22470] [ 5] rhoSimpleFoam(+0x2ae46)[0x5569ee4d0e46]
[mae-hen-8163-db:22470] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7fd153ba8b97]
[mae-hen-8163-db:22470] [ 7] rhoSimpleFoam(+0x2f96a)[0x5569ee4d596a]
[mae-hen-8163-db:22470] *** End of error message ***
[mae-hen-8163-db:22469] *** Process received signal ***
[mae-hen-8163-db:22469] Signal: Floating point exception (8)
[mae-hen-8163-db:22469] Signal code:  (-6)
[mae-hen-8163-db:22469] Failing at address: 0x3e9000057c5
[mae-hen-8163-db:22469] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f09068fcf20]
[mae-hen-8163-db:22469] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7f09068fce97]
[mae-hen-8163-db:22469] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f09068fcf20]
[mae-hen-8163-db:22469] [ 3] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE9calculateEv+0x305)[0x7f090c3d3825]
[mae-hen-8163-db:22469] [ 4] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE7correctEv+0x2a)[0x7f090c3e587a]
[mae-hen-8163-db:22469] [ 5] rhoSimpleFoam(+0x2ae46)[0x55a1f26bee46]
[mae-hen-8163-db:22469] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f09068dfb97]
[mae-hen-8163-db:22469] [ 7] rhoSimpleFoam(+0x2f96a)[0x55a1f26c396a]
[mae-hen-8163-db:22469] *** End of error message ***
mpirun noticed that process rank 0 with PID 0 on node mae-hen-8163-db exited on signal 8 (Floating point exception).
I noted that the max pressure
probably was going beyond the set limits:
pressureControl
    pMax 165000
    pMin 40494
So I changed the criteria in fvSolutions and increased pMax coefficient to 3.5. But this did not change the situation.
New errors do not include the pMax warning line but solver fails nonetheless:
Create time
    type            hePsiThermo;
    thermo          hConst;
    specie          specie;
Reading field U
pressureControl
    pMax 385000
    pMin 40494
Starting time loop
Time = 1
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.0628742, No Iterations 2
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.0314271, No Iterations 2
time step continuity errors : sum local = 4744.6, global = -3840.21, cumulative = -3840.21
ExecutionTime = 4.31 s  ClockTime = 4 s
Time = 2
smoothSolver:  Solving for Ux, Initial residual = 0.112656, Final residual = 0.00870786, No Iterations 4
smoothSolver:  Solving for Uy, Initial residual = 0.663654, Final residual = 0.0119271, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 0.169241, Final residual = 0.015536, No Iterations 4
smoothSolver:  Solving for e, Initial residual = 0.807748, Final residual = 0.0016073, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.978126, Final residual = 0.0452372, No Iterations 6
time step continuity errors : sum local = 1138.36, global = -218.941, cumulative = -4059.15
ExecutionTime = 7.28 s  ClockTime = 7 s
Time = 3
smoothSolver:  Solving for Ux, Initial residual = 0.280108, Final residual = 0.0257687, No Iterations 4
smoothSolver:  Solving for Uy, Initial residual = 0.805069, Final residual = 0.0705581, No Iterations 4
smoothSolver:  Solving for Uz, Initial residual = 0.473923, Final residual = 0.0284756, No Iterations 6
smoothSolver:  Solving for e, Initial residual = 0.528692, Final residual = 0.00947931, No Iterations 1
[mae-hen-8163-db:24641] *** Process received signal ***
[mae-hen-8163-db:24641] Signal: Floating point exception (8)
[mae-hen-8163-db:24641] Signal code:  (-6)
[mae-hen-8163-db:24641] Failing at address: 0x3e900006041
[mae-hen-8163-db:24641] [mae-hen-8163-db:24639] *** Process received signal ***
[mae-hen-8163-db:24639] Signal: Floating point exception (8)
[mae-hen-8163-db:24639] Signal code:  (-6)
[mae-hen-8163-db:24639] Failing at address: 0x3e90000603f
[mae-hen-8163-db:24639] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f0e3850af20]
[mae-hen-8163-db:24639] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7f0e3850ae97]
[mae-hen-8163-db:24639] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f0e3850af20]
[mae-hen-8163-db:24639] [ 3] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE9calculateEv+0x305)[0x7f0e3dfe1825]
[ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7fa802966f20]
[mae-hen-8163-db:24641] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7fa802966e97]
[mae-hen-8163-db:24641] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7fa802966f20]
[mae-hen-8163-db:24641] [ 3] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE9calculateEv+0x305)[0x7fa80843d825]
[mae-hen-8163-db:24641] [ 4] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE7correctEv+0x2a)[0x7fa80844f87a]
[mae-hen-8163-db:24641] [ 5] rhoSimpleFoam(+0x2ae46)[0x559c59b77e46]
[mae-hen-8163-db:24641] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7fa802949b97]
[mae-hen-8163-db:24641] [ 7] rhoSimpleFoam(+0x2f96a)[0x559c59b7c96a]
[mae-hen-8163-db:24641] *** End of error message ***
[mae-hen-8163-db:24639] [ 4] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE7correctEv+0x2a)[0x7f0e3dff387a]
[mae-hen-8163-db:24639] [ 5] rhoSimpleFoam(+0x2ae46)[0x558b08c76e46]
[mae-hen-8163-db:24639] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f0e384edb97]
[mae-hen-8163-db:24639] [ 7] rhoSimpleFoam(+0x2f96a)[0x558b08c7b96a]
[mae-hen-8163-db:24639] *** End of error message ***
[mae-hen-8163-db:24638] *** Process received signal ***
[mae-hen-8163-db:24638] Signal: Floating point exception (8)
[mae-hen-8163-db:24638] Signal code:  (-6)
[mae-hen-8163-db:24638] Failing at address: 0x3e90000603e
[mae-hen-8163-db:24638] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7fafff9cbf20]
[mae-hen-8163-db:24638] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7fafff9cbe97]
[mae-hen-8163-db:24638] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7fafff9cbf20]
[mae-hen-8163-db:24638] [ 3] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE9calculateEv+0x305)[0x7fb0054a2825]
[mae-hen-8163-db:24638] [ 4] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE7correctEv+0x2a)[0x7fb0054b487a]
[mae-hen-8163-db:24638] [ 5] rhoSimpleFoam([mae-hen-8163-db:24640] *** Process received signal ***
+0x2ae46)[0x55c13f784e46]
[mae-hen-8163-db:24638] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7fafff9aeb97]
[mae-hen-8163-db:24638] [ 7] rhoSimpleFoam(+0x2f96a)[0x55c13f78996a]
[mae-hen-8163-db:24638] *** End of error message ***
[mae-hen-8163-db:24640] Signal: Floating point exception (8)
[mae-hen-8163-db:24640] Signal code:  (-6)
[mae-hen-8163-db:24640] Failing at address: 0x3e900006040
[mae-hen-8163-db:24640] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f2b6052bf20]
[mae-hen-8163-db:24640] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7f2b6052be97]
[mae-hen-8163-db:24640] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f2b6052bf20]
[mae-hen-8163-db:24640] [ 3] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE9calculateEv+0x305)[0x7f2b66002825]
[mae-hen-8163-db:24640] [ 4] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE7correctEv+0x2a)[0x7f2b6601487a]
[mae-hen-8163-db:24640] [ 5] rhoSimpleFoam(+0x2ae46)[0x5632368e1e46]
[mae-hen-8163-db:24640] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f2b6050eb97]
[mae-hen-8163-db:24640] [ 7] rhoSimpleFoam(+0x2f96a)[0x5632368e696a]
[mae-hen-8163-db:24640] *** End of error message ***
mpirun noticed that process rank 1 with PID 0 on node mae-hen-8163-db exited on signal 8 (Floating point exception).
I have following boundary conditions for the fully laminar case:
U
inlet1: flowRateInletVelocity;
        volumetricFlowRate    constant 0.0011;
inlet2: flowRateInletVelocity;
        volumetricFlowRate   constant 1e-5;
outlet: inletOutlet
p
inlet1: zeroGradient;
inlet2: fixedValue;
       value            uniform 1.1e5;
outlet: fixedValue;
       value            $internalField;
The pressure inlet for inlet 2 is a requirement and cannot be changed. fvSolution and fvSchemes are exactly as the tutorials for rhoSimpleFoam.
Does anyone spot a problem in here? Why am I getting the time step errors for a seemingly very simple problem?
deepbandivadekar is offline   Reply With Quote
Old   September 12, 2018, 16:29
Thomas M
tmik is on a distinguished road
Where and how did you change fvSolutions to include pMax? Could you provide the code you used for this?
tmik is offline   Reply With Quote
Old   September 13, 2018, 05:50
Deep
In the SIMPLE subdictionary of fvSolutions:
SIMPLE
    nNonOrthogonalCorrectors 0;
    pMinFactor      0.4;
    pMaxFactor      1.5;
    residualControl
        p               1e-2;
        U               1e-4;
        e               1e-3;
        "(k|epsilon|omega)" 1e-3;
However, be aware that this could be a superficial solution. Like in my case, the real reason for the issue could be somewhere in the setup. For me, it was bad boundary conditions. I managed to get past this error.
tmik likes this.
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
InterFoam negative alpha karasa03 OpenFOAM 7 December 12, 2013 03:41
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
