Plotting courant number from rhoPimpleFoam in paraview?
Like Tree8Likes
  • 1 Post By KarenRei
  • 4 Post By RobertHB
  • 3 Post By miotto
Old   October 1, 2018, 21:19
Default Plotting courant number from rhoPimpleFoam in paraview?
Anonymouse
KarenRei is on a distinguished road
I've got a simulation that's running abnormally slow in order to try to prevent exceeding its specified maximum courant number. Looking at the data in paraview, nothing appears out of the ordinary. So the idea obviously came to mind to plot the courant number itself in paraview / parafoam. However, "postProcess -func CourantNo" is giving up:
--> FOAM FATAL ERROR:
    request for volScalarField rho from objectRegistry region0 failed
    available objects of type volScalarField are
1(surfaceSum(mag(phi)))
    From function const Type& Foam::objectRegistry::lookupObject(const Foam::word&, bool) const [with Type = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>]
    in file /opt/OpenFOAM-v1806/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 239.
Thoughts?
miotto likes this.
KarenRei is offline   Reply With Quote
Old   October 2, 2018, 00:01
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
It is much easier to send the log file through a grep or awk script which gives the Courant number together with some other data like simulated time.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   October 2, 2018, 03:21
Robert
RobertHB is on a distinguished road
OpenFoam also offers a Courant Number function which you can add to your controlDict.
functions
#includeFunc CourantNo
Source.
And then you could use the foam monitor to plot the Co number if i'm not mistaken.
If you liked my answer to your question, please consider leaving a "Like" in return
RobertHB is offline   Reply With Quote
Old   October 2, 2018, 05:35
Anonymouse
That would give the max and average courant number, but not show where the number is high.
Old   October 2, 2018, 05:36
Anonymouse
functions
Source.
How would foamMonitor show me in what cells the courant number is high?
Old   October 2, 2018, 07:29
Robert
It doesn't, i misunderstood your endavour. You can always calculate your Co. in paraview with the calculator. But it will be an mirrorimage of your velocity.
Old   October 2, 2018, 07:32
Anonymouse
It's more than just velocity, the cell size with respect to the velocity vector matters. It's not enough just to display U in paraview.
Old   February 18, 2020, 14:04
Gui Miotto
miotto is on a distinguished road
So here is how you do it:
First, you add the Courant number function object to your ControlDict:
functions
    Co1
        type                CourantNo;
        libs                ("libfieldFunctionObjects.so");
        executeControl      timeStep;
        executeInterval     2;
        writeControl        writeTime;
Run you simulation and open paraView. There you have to add the VolumeField Co by checking the "Co" checkbox under Properties/Volume Fields and clicking on apply.
Then advance to the second timestep of you simulation and the Co will be available for visualization (as the other regular variables - pressure, velocity, etc.)
miotto is offline   Reply With Quote
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 21:00
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
