why my bubble is bursting in static bubble test |
November 10, 2018, 07:27 |
krishna kant
Rep Power: 10 |
Hello Foamers
I am trying to solve a static bubble test as given in Albadawi et. al. My problem is my bubble is bursting when I refine my mesh. It work fine when there is 10 divisions per diameter but it burst if I do 20 divisions per diameter. The link for Albadawi et. al. is given below: https://www.sciencedirect.com/scienc...01932213000190 The drop radius=0.005m in a domain of 0.05x0.05. Fluid density=1000 gas density=1 kinematic viscosity for fluid = 1e-3 kinematic viscosity for gas = 1e-5 Surface Tension between the fluids = 0.01 All in S.I unit I am using the sclsVOFFoam solver developed by chalmers http://www.tfd.chalmers.se/~hani/kur...ankarMenon.pdf I tried with various boundary conditions zero gradient, fixed value, slip, cyclic none is working. Can someone suggest whats wrong am I doing!! |
November 28, 2018, 00:38 |
krishna kant
Rep Power: 10 |
In the given test case of sclsVOFFoam why the setFields is between
p1 (0.25 0.5 -1) ; p2 (0.75 0.5 1) ; Shouldn't it be from p1 (0.5 0.5 -1) ; p2 (0.5 0.5 1) ; |
A new test harness for OpenFOAM | mbeaudoin | OpenFOAM Announcements from Other Sources | 0 | June 17, 2010 10:36 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
test cases | Maciej Matyka | Main CFD Forum | 3 | November 24, 2004 08:27 |
