--> FOAM FATAL ERROR:request for volTensorField sigmap |
November 13, 2018, 23:55 |
Xuxiang Cao
Rep Power: 9 |
hello everyone
when i used pisoFoam to solve a problem about simulating 1/4 of underwater glider body with k-omega model, i encountered an error from openfoam. the full information is given: Code:
Create time Create mesh for time = 0 SIMPLE: no convergence criteria found. Calculations will run for 10000 steps. Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST Selecting patchDistMethod meshWave kOmegaSSTCoeffs { alphaK1 0.85; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.856; gamma1 0.555556; gamma2 0.44; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; } No MRF models present No finite volume options present Starting time loop forces forceCoeffs1: Not including porosity effects forceCoeffs forceCoeffs1: Not including porosity effects Time = 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0910522, No Iterations 22 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0919569, No Iterations 19 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.093001, No Iterations 11 GAMG: Solving for p, Initial residual = 1, Final residual = 0.00820068, No Iterations 35 time step continuity errors : sum local = 8.31086e-05, global = -2.6e-05, cumulative = -2.6e-05 smoothSolver: Solving for omega, Initial residual = 0.0145231, Final residual = 0.0013093, No Iterations 5 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0768991, No Iterations 6 ExecutionTime = 62.16 s ClockTime = 63 s --> FOAM FATAL ERROR: request for volTensorField sigmap from objectRegistry region0 failed available objects of type volTensorField are 1(grad(U)) From function const Type& Foam::objectRegistry::lookupObject(const Foam::word&) const [with Type = Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>] in file /vol/home/caoxuxiang/OpenFOAM/OpenFOAM-4/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 193. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ~/OpenFOAM/OpenFOAM-4/src/OSspecific/POSIX/printStack.C:218 #1 Foam::error::abort() at ~/OpenFOAM/OpenFOAM-4/src/OpenFOAM/lnInclude/error.C:249 #2 Foam::Ostream& Foam::operator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) at ~/OpenFOAM/OpenFOAM-4/src/OpenFOAM/lnInclude/errorManip.H:85 #3 Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> const& Foam::objectRegistry::lookupObject<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const at ~/OpenFOAM/OpenFOAM-4/src/OpenFOAM/lnInclude/objectRegistryTemplates.C:193 #4 Foam::functionObjects::forces::calcForcesMoment() at ~/OpenFOAM/OpenFOAM-4/src/functionObjects/forces/forces/forces.C:799 #5 Foam::functionObjects::forceCoeffs::write() at ~/OpenFOAM/OpenFOAM-4/src/functionObjects/forces/forceCoeffs/forceCoeffs.C:180 #6 Foam::functionObjects::timeControl::write() at ~/OpenFOAM/OpenFOAM-4/src/OpenFOAM/db/functionObjects/timeControl/timeControlFunctionObject.C:106 #7 Foam::functionObjectList::execute() at ~/OpenFOAM/OpenFOAM-4/src/OpenFOAM/db/functionObjects/functionObjectList/functionObjectList.C:476 #8 Foam::Time::run() const at ~/OpenFOAM/OpenFOAM-4/src/OpenFOAM/db/Time/Time.C:880 #9 Foam::Time::loop() at ~/OpenFOAM/OpenFOAM-4/src/OpenFOAM/db/Time/Time.C:889 #10 Foam::simpleControl::loop() at ~/OpenFOAM/OpenFOAM-4/src/finiteVolume/cfdTools/general/solutionControl/simpleControl/simpleControl.C:154 #11 ? at ~/OpenFOAM/OpenFOAM-4/applications/solvers/incompressible/simpleFoam/simpleFoam.C:59 #12 __libc_start_main in "/lib64/libc.so.6" #13 ? in "/vol/home/caoxuxiang/OpenFOAM/OpenFOAM-4/platforms/linux64GccDPInt32Debug/bin/simpleFoam" Aborted (core dumped) However, when I cancelled part of functions from controlDict, I did not encounter this problem. the controlDict: Code:
application simpleFoam; startFrom latestTime; startTime 1; stopAt endTime; endTime 10000; deltaT 1; writeControl timeStep; writeInterval 200; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression uncompressed; timeFormat general; timePrecision 6; runTimeModifiable no; adjustTimeStep no; functions { forceCoeffs1 { type forceCoeffs; libs ("libforces.so"); writeControl timeStep; writeInterval 1; patches (wall); rho rhoInf; rhoInf 1025; log yes; CoR (0 0 0); dragDir (1 0 0); liftDir (0 1 0); pitchAxis (0 0 1); magUInf 1.0; lRef 1.0; Aref 0.465; origin (0 0 0); coordinateRotation { type EulerRotation; degrees true; rotation (0 0 0); } } thanks. Xuxiang |
November 15, 2018, 20:32 |
Xuxiang Cao
Rep Power: 9 |
hi guys:
i simulated my case with openfoam-2.4.0, and it had no wrong information. it shill worked well even i added the forceCoeffs function in controlDict file. why happened this between different version of openfoam? |
November 16, 2018, 00:12 |
Ran
Rep Power: 9 |
The force function do the bad thing, maybe try the following lines to your control file:
``` libs ("libOpenFOAM.so" "libfieldFunctionObjects.so"); ```
Yours in CFD, Ran Last edited by random_ran; November 16, 2018 at 00:21. Reason: eww not good at editing... do you have any suggestion? |
voltensorfield sigmap |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
error with reactingFoam | BakedAlmonds | OpenFOAM Running, Solving & CFD | 4 | June 22, 2016 02:21 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
