November 25, 2018, 11:29 |
reactingFoam Sandia
Boris Kurowski
Hallo guys,
i changed in the tutorial of reactingFoam/RAS/Sandia_LTS the blockMesh to study my simulation. Therefore I wanted to run the simulation without the wallthikness and than I put the two inlet pipes together: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.001; vertices ( (0 0 -150) // 0 E-1 jet (3.6 -0.1571793944724 -150) // 1 (3.6 0.1571793944724 -150) // 2 (3.6 -0.1571793944724 -150) // 3 E-1 pilot ohne Wandung 0,25mm (3.6 0.1571793944724 -150) // 4 (9.1 -0.3973145804719 -150) // 5 (9.1 0.3973145804719 -150) // 6 (0 0 0) // 7 E0 CH4 (3.6 -0.1571793944724 0) // 8 (3.6 0.1571793944724 0) // 9 (3.6 -0.1571793944724 0) // 10 E0 pilot ohne Wandung (3.6 0.1571793944724 0) // 11 (9.1 -0.3973145804719 0) // 12 (9.1 0.3973145804719 0) // 13 (150 -6.54914143635 0) // 14 E0 coflow (150 6.54914143635 0) // 15 (0 0 800) // 16 E1 jet (3.6 -0.1571793944724 800) // 17 (3.6 0.1571793944724 800) // 18 (3.6 -0.1571793944724 800) // 19 E1 pilot (3.6 0.1571793944724 800) // 20 (9.1 -0.3973145804719 800) // 21 (9.1 0.3973145804719 800) // 22 (150 -6.54914143635 800) // 23 E1 coflow (150 6.54914143635 800) // 24 ); blocks ( hex ( 0 1 2 0 7 8 9 7) (5 1 40) simpleGrading (1 1 1) //Jet hex ( 3 5 6 4 10 12 13 11) (5 1 40) simpleGrading (1 1 1) //Pilot hex ( 7 8 9 7 16 17 18 16) (5 1 400) simpleGrading (1 1 2) //Brennraum jet hex (10 12 13 11 19 21 22 20) (5 1 400) simpleGrading (1 1 2) //Brennraum pilot hex (12 14 15 13 21 23 24 22) (38 1 400) simpleGrading (3 1 2) //Brennraum coflow ); boundary ( inletCH4 { type patch; faces ( (1 0 0 2) ); } wallOutside { type wall; faces ( (14 15 24 23) ); } wallTube { type wall; faces ( (1 2 9 8) (4 3 10 11) (5 6 13 12) ); } inletPilot { type patch; faces ( (5 3 4 6) ); } inletAir { type patch; faces ( (14 12 13 15) ); } outlet { type patch; faces ( (16 17 18 16) (19 21 22 20) (21 22 24 23) ); } axis { type empty; faces ( (0 7 7 0) (7 16 16 7) ); } frontAndBack_pos { type wedge; faces ( (2 0 7 9) (6 4 11 13) (9 7 16 18) (13 11 20 22) (15 13 22 24) ); } frontAndBack_neg { type wedge; faces ( (0 1 8 7) (3 5 12 10) (7 8 17 16) (10 12 21 19) (12 14 23 21) ); } ); // ************************************************** *********************** // The blockMesh works and the checkMesh says ok, but if run the ractingFoam I have this error upcoming: /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 6-1a0c91b3baa8 Exec : reactingFoam Date : Nov 23 2018 Time : 18:13:03 Host : "boris-VirtualBox" PID : 30108 I/O : uncollated Case : /home/boris/CFD/OpenFOAM/dummy_23 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: No convergence criteria found PIMPLE: Operating solver in PISO mode Using LTS Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture reactingMixture; transport sutherland; thermo janaf; energy sensibleEnthalpy; equationOfState perfectGas; specie specie; } Selecting chemistryReader foamChemistryReader Reading field U Reading/calculating face flux field phi Creating turbulence model. Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon RAS { RASModel kEpsilon; turbulence on; printCoeffs on; Cmu 0.09; C1 1.44; C2 1.92; C3 0; sigmak 1; sigmaEps 1.3; } Creating reaction model Selecting combustion model EDC<psiChemistryCombustion> --> FOAM Warning : From function static Foam::autoPtr<T> Foam::combustionModel::New(typename CombustionModel::reactionThermo&, const Foam::compressibleTurbulenceModel&, const Foam::word&) [with CombustionModel = Foam::CombustionModel<Foam:siReactionThermo>; typename CombustionModel::reactionThermo = Foam:siReactionThermo] in file /home/ubuntu/OpenFOAM/OpenFOAM-6/src/combustionModels/lnInclude/combustionModelTemplates.C at line 69 Template parameters are no longer required when selecting a combustionModel. This information is now obtained directly from the thermodynamics. Actually selecting combustion model EDC. Selecting chemistry solver { solver ode; method TDAC; } StandardChemistryModel: Number of species = 36 and reactions = 219 Selecting chemistry reduction method DAC element not considered Selecting chemistry tabulation method ISAT Selecting ODE solver seulex using integrated reaction rate Creating field dpdt Creating field kinetic energy K No MRF models present Creating finite volume options from "constant/fvOptions" Selecting finite volume options model type radiation Source: radiation Selecting radiationModel P1 Selecting absorptionEmissionModel greyMeanAbsorptionEmission Selecting scatterModel none Selecting sootModel none Starting time loop --> FOAM Warning : From function void Foam:article::locate(const vector&, const vector*, Foam::label, bool, Foam::string) in file particle/particle.C at line 493 "Particle initialised with a location outside of the mesh." --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 746 Caught FatalError --> FOAM FATAL ERROR: Unknown sample set type uniform The sample set type uniform has been renamed lineUniform Replace "type uniform;" with "type lineUniform;" for the set x_d_15 in "/home/boris/CFD/OpenFOAM/dummy_23/system/sampleDict.sets" From function static Foam::autoPtr<Foam::sampledSet> Foam::sampledSet::New(const Foam::word&, const Foam:olyMesh&, const Foam::meshSearch&, const Foam::dictionary&) in file sampledSet/sampledSet/sampledSet.C at line 161. Time scales min/max: Flow = 4.083092965e-05, 0.0001 Temperature = 4.494232837e+307, 4.494232837e+307 Composition = 4.494232837e+307, 4.494232837e+307 Overall = 4.083092965e-05, 0.0001 Time = 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCGStab: Solving for Uy, Initial residual = 0.9999999754, Final residual = 0.002849317421, No Iterations 1 DILUPBiCGStab: Solving for Uz, Initial residual = 0.9999999993, Final residual = 0.0009886161378, No Iterations 1 DILUPBiCGStab: Solving for H2, Initial residual = 1, Final residual = 0.00400863106, No Iterations 1 DILUPBiCGStab: Solving for H, Initial residual = 1, Final residual = 0.00400863106, No Iterations 1 DILUPBiCGStab: Solving for O, Initial residual = 1, Final residual = 0.00400863106, No Iterations 1 DILUPBiCGStab: Solving for O2, Initial residual = 0.99999994, Final residual = 0.003262125792, No Iterations 1 DILUPBiCGStab: Solving for OH, Initial residual = 1, Final residual = 0.00400863106, No Iterations 1 DILUPBiCGStab: Solving for H2O, Initial residual = 1, Final residual = 0.00400863106, No Iterations 1 DILUPBiCGStab: Solving for HO2, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCGStab: Solving for CH4, Initial residual = 1, Final residual = 0.00101207502, No Iterations 1 DILUPBiCGStab: Solving for CO, Initial residual = 1, Final residual = 0.00400863106, No Iterations 1 DILUPBiCGStab: Solving for CO2, Initial residual = 1, Final residual = 0.00400863106, No Iterations 1 DICPCG: Solving for G, Initial residual = 1, Final residual = 9.182754125e-06, No Iterations 492 DILUPBiCGStab: Solving for h, Initial residual = 1, Final residual = 0.0002459968421, No Iterations 1 min/max(T) = 291, 1880 DICPCG: Solving for p, Initial residual = 0.9999999995, Final residual = 0.00924505048, No Iterations 35 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 5.987539369e-07, global = -1.213616321e-07, cumulative = -1.213616321e-07 DICPCG: Solving for p, Initial residual = 0.9659863197, Final residual = 9.407598315e-07, No Iterations 109 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 2.747274333e-08, global = 2.811622849e-10, cumulative = -1.210804698e-07 DILUPBiCGStab: Solving for epsilon, Initial residual = 0.9999999885, Final residual = 0.02094788957, No Iterations 1 bounding epsilon, min: -7.545995368e+13 max: 1.692055105e+13 average: -1.129936214e+12 DILUPBiCGStab: Solving for k, Initial residual = 1, Final residual = 0.0003996662989, No Iterations 1 bounding k, min: -4.462773291e+10 max: 76401942.73 average: -575399021.1 ExecutionTime = 4.89 s ClockTime = 5 s Time scales min/max: Flow = 3.769153522e-07, 0.0001 Temperature = 4.494232837e+307, 4.494232837e+307 Composition = 4.494232837e+307, 4.494232837e+307 Overall = 3.769153522e-07, 0.0001 Time = 2 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCGStab: Solving for Uy, Initial residual = 0.6098529666, Final residual = 6.741850122e+11, No Iterations 1000 DILUPBiCGStab: Solving for Uz, Initial residual = 0.6797828315, Final residual = 0.04694567801, No Iterations 1 Can somebody help me out? Thank you very much |
reactingFoam problem | kane | OpenFOAM Running, Solving & CFD | 1 | January 8, 2019 17:51 |
How to switch off combustion and reaction in reactingFoam | shenzhou1987 | OpenFOAM Running, Solving & CFD | 16 | October 26, 2017 15:31 |
strange processor boundary behavior in foam-extend reactingFOAM | Neka | OpenFOAM Bugs | 8 | August 16, 2017 07:13 |
reactingFoam wedge handling wrong U | dhondupant | OpenFOAM Bugs | 1 | December 9, 2010 07:34 |
reactingFoam - turbulent reacting flow | hamburgFoam | OpenFOAM | 0 | December 7, 2009 12:57 |
