November 30, 2018, 08:04 |
Detached eddy simulation - OpenFoam
madz
Rep Power: 7 |
Hello!!
I'm simulating a supersonic cavity using DES (k omega SST) in OpenFoam. Can anyone tell me where I can find a tutorial case for the same? I'm just a beginner in DES. Kindly help asap!! |
December 4, 2018, 22:58 |
Sai Guruprasad Jakkala
Rep Power: 9 |
Hello!!
There are no tutorials for k- SST DES model in OF. You can try to run the case by building it similar to SA DES case. The 0 folder requires k, U, omega, nut and p. The fvSolution and fvSchemes can be chosen from the DES tutorial case. Let me know if you are able to get good results using k- SST DES. |
December 4, 2018, 23:31 |
madz
Rep Power: 7 |
Hi SaiGuru Prasad!
Thanks! That helps a lot. Can you please tell me where I can find DES tutorial cases for SA model? |
December 5, 2018, 00:22 |
Rep Power: 9 |
tutorials/incompressible/pisoFoam/LES/motorbike/lesFiles |
Pressure drop in pipe flow with Large Eddy Simulation | xerox | FLUENT | 1 | October 16, 2019 08:55 |
OpenFoam 4.1: interDyMFoam LES Simulation for hydro turbine in river | pi__sec | OpenFOAM Running, Solving & CFD | 13 | July 19, 2017 04:08 |
UNIGE February 13th-17th - 2107. OpenFOAM advaced training days | joegi.geo | OpenFOAM Announcements from Other Sources | 0 | October 1, 2016 19:20 |
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 14, 2016 03:19 |
Detached Eddy Simulation in industry | Fab | Main CFD Forum | 3 | January 18, 2007 14:50 |
