Weird thing in AMI boundary condition in OpenFOAM
Old   December 3, 2018, 14:49
Default Weird thing in AMI boundary condition in OpenFOAM
Morteza
mortezahdr is on a distinguished road
I have noticed a weird thing about sliding-mesh problems in OpenFOAM. Consider two cases:
1. You use snappyHexmesh, topoSet and createPatch to build the mesh, cell-zones and boundary conditions.
2. You generate the mesh outside the OpenFOAM (like Pointwise, etc) and then topoSet and createPatch.
The weird thing is that following method 1, you do not need to specify AMI patch in initialization files in 0 folder (U, p, nut, omega,k). You may run the case and OpenFOAM does not complain about that. But following method 2, OpenFOAM says:
Cannot find patchField entry for AMI1 (or whatever the AMI patch name is).
while in both cases, you have the two AMI patches in your boundary file (after running createPatch). Does anybody know the reason?
mortezahdr is offline   Reply With Quote
Old   December 3, 2018, 15:31
Morteza
The problem is solved. The reason was including the following lines in OpenFOAM's case setup:
//- Set patchGroups for constraint patches
#includeEtc "caseDicts/setConstraintTypes"
OpenFOAM 4.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 2 October 6, 2017 05:40
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 10:20
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 13:38
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
