non-Orthogonal correction for a rungeKutta solver
Like Tree1Likes
  • 1 Post By Santiago
Old   January 30, 2019, 02:35
Default non-Orthogonal correction for a rungeKutta solver
Vu
DoQuocVu is on a distinguished road
Dear Foamers,
I implemented a Navier-Stokes solver using a 3 step Runge-Kutta scheme following these steps:
The solver works fine with orthogonal mesh as I validated it with the lid-driven cavity. However, when it comes to the flow over cylinder problem, where the mesh consists of multi-block and is non-orthogonal, the simulation diverged. The results before it crashed:
As far as I know with simpleFoam or pisoFoam, nonOrthogonality can be treated by choosing a corrected scheme for the laplacianSchemes and the snGradSchemes, along with nonOrthogonalCorrectors loops.
In my current solver, it clearly doesn't need non-Orthogonal correction loops. I think that when choosing the corrected scheme, the correction term would be automatically evaluated in the discretization process of the laplacian term. So I expected the following setup would work, but it doesn't:
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss linearlimitedLinearV 1;
    div(phi,k)      Gauss limitedLinear 1;
    div(phi,epsilon) Gauss limitedLinear 1;
    div(phi,R)      Gauss limitedLinear 1;
    div(R)          Gauss linear;
    div(U)            Gauss linear;
    div(phi,nuTilda) Gauss limitedLinear 1;
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
    interpolate(U)  linear;
snGradSchemes
    default         corrected;
Am I wrong about the corrected scheme? I would appreciate any suggestion!
DoQuocVu is offline   Reply With Quote
Old   January 30, 2019, 03:00
Vu
Here is the main loop of the solver:
while (runTime.run())
    #include "readTimeControls.H"
    #include "CourantNo.H"
    #include "setDeltaT.H"
    runTime++;
    Info<< "Time = " << runTime.timeName() << nl << endl;
    const dimensionedScalar dT = runTime.deltaT();
    for(int k=1; k<nStep+1; k++)
        //.1- Explicitly calculate u tildle.
        if (k==1)
            Uk_1 = U.oldTime();
            pk_1 = p.oldTime();
            surfaceScalarField phik_1
                "phik_1",
                linearInterpolate(Uk_1) & mesh.Sf()
            U_tildle = Uk_1 + dT*(  2.0*alpha[k]*nu*fvc::laplacian(Uk_1)
                                  - 2.0*alpha[k]*fvc::grad(pk_1)
                                  - gamma[k]*fvc::div(phik_1, Uk_1)
        else
                "phik_1",
            surfaceScalarField phik_2
                "phik_2",
                linearInterpolate(Uk_2) & mesh.Sf()
                                   - zeta[k]*fvc::div(phik_2, Uk_2)
        //2. calculating UStar
        volVectorField UStar(U);
        forAll(UStar.internalField(), cellI)
            UStar[cellI] = vector::zero;
        fvVectorMatrix UStarEqn
            fvm::laplacian(UStar)
        for (label i=0; i<mesh.nCells(); i++)
            UStarEqn.diag()[i] -= mesh.V()[i]/(alpha[k]*nu.value()*dT.value());
        solve
            UStarEqn
                - (U_tildle/dT + ibForce_ + gradP)/(nu*alpha[k])
                + fvc::laplacian(Uk_1)
        //3. Solve for immediate pressure
        volScalarField pImd(p);
        forAll(pImd.internalField(), cellI)
        pImd[cellI] = 0.0;
        fvScalarMatrix pImdEqn
            fvm::laplacian(pImd) == fvc::div(UStar)/(2.0*alpha[k]*dT)
        pImdEqn.solve();
       //4. Correct velocity
        Uk = UStar - 2.0*alpha[k]*dT*fvc::grad(pImd);
       //5. Update pressure
        pk = pk_1 + pImd - alpha[k]*nu*dT*fvc::laplacian(pImd);
     Uk_2 = Uk_1;
     Uk_1 = Uk;
     pk_1 = pk;
U = Uk;
p = pk;
#include "continuityErrs.H"
phi = fvc::flux(U);
U.correctBoundaryConditions();
runTime.write();
Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
    << "  ClockTime = " << runTime.elapsedClockTime() << " s"
    << nl << endl;
Old   February 2, 2019, 05:39
Santiago Lopez Castano
Santiago is on a distinguished road
Which is the source/article on which you base the algorithm?
MRAJALIN likes this.
Santiago is offline   Reply With Quote
Old   April 19, 2019, 03:36
Vu
Hi Santiago,
Its been a while and until now I have time to back to this work.
Actually, I was implementing the immersed boundary method as in this journal:
https://arxiv.org/abs/1809.08170
The immersed boundary technique, however, does not work well with the PISO algorithm as I expected. That's why I wanted to try it with the 3step runge Kutta described in the article.
PEMFC model with FLUENT brahimchoice FLUENT 22 April 19, 2020 15:44
Divergence detected in AMG solver: pressure correction CMICT FLUENT 4 June 14, 2016 12:08
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
Explicit Solver and pressure correction hjasak OpenFOAM Running, Solving & CFD 1 October 5, 2006 07:16
