Can't get chtMultiRegionSimpleFoam to working.
Like Tree1Likes
  • 1 Post By Bloerb
Old   January 31, 2019, 00:25
Post Can't get chtMultiRegionSimpleFoam to working.
Shiromani Chandra
shiromaniac is on a distinguished road
Hey Foamers,
I am an amateur in CFD and OpenFoam and I have been assigned to do a relatively difficult task( as far as my standards are concerned).
For starters, I am supposed to perform incompressible flow past a heated(having internal heat generation) rectangular cylinder using chtMultiRegionSimpleFoam.
Although, it seemed like a herculean task at first but I somehow managed to mesh both my regions (Domain and Cell) using salome and used ideasUnvToFoam to convert the mesh into OpenFoam readable format.
The issue which I am facing is I just cant get my solver to run. I am attaching my case as well as the errors coming when I run simulation. Please, please please somebody help!
On running Allrun script the following output comes:
| \\ / O peration | Version: 5.0 |
| \\/ M anipulation | |
Build : 5.x-197d9d3bf20a
Exec : chtMultiRegionSimpleFoam
Date : Jan 31 2019
Time : 10:08:42
Host : "openfoam-VirtualBox"
PID : 18147
I/O : uncollated
Case : /home/openfoam/Desktop/planewall/planeWall2Docomp
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create fluid mesh for region Domain for time = 0
Create solid mesh for region Cell for time = 0
*** Reading fluid mesh thermophysical properties for region Domain
Adding to thermoFluid
Selecting thermodynamics package
type heRhoThermo;
mixture pureMixture;
transport const;
thermo hConst;
equationOfState perfectGas;
specie specie;
energy sensibleEnthalpy;
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::heRhoThermo<Foam::rhoThermo, Foam:ureMixture<Foam::constTransport<Foam::speci es::thermo<Foam::hConstThermo<Foam:erfectGas<Foa m::specie> >, Foam::sensibleEnthalpy> > > >::calculate() at ??:?
#4 Foam::rhoThermo::addfvMeshConstructorToTable<Foam: :heRhoThermo<Foam::rhoThermo, Foam:ureMixture<Foam::constTransport<Foam::speci es::thermo<Foam::hConstThermo<Foam:erfectGas<Foa m::specie> >, Foam::sensibleEnthalpy> > > > >::New(Foam::fvMesh const&, Foam::word const&) at ??:?
#5 Foam::autoPtr<Foam::rhoThermo> Foam::basicThermo::New<Foam::rhoThermo>(Foam::fvMe sh const&, Foam::word const&) at ??:?
#6 Foam::rhoThermo::New(Foam::fvMesh const&, Foam::word const&) at ??:?
#7 ? at ??:?
#8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#9 ? at ??:?
Floating point exception (core dumped)
I would have shared my case but its size is exceeding the allowable size limit.
Please Help!
shiromaniac is offline   Reply With Quote
Old   January 31, 2019, 03:49
Bloerb will become famous soon enough
Well this sadly tells us nothing. It crashes during setup hence something fundamental is wrong. Delete everything inside all of the polyMesh folders except the boundary file and upload it.
Bloerb is offline   Reply With Quote
Old   January 31, 2019, 05:46
Default Can't get chtMultiRegionSimpleFoam to working.
Shiromani Chandra
Thanks for your quick reply. I did what you said but it turned out that it is my mesh which is large and even after compressing it comes down to 1.4MB. I am attaching my case here. As far as mesh is concerned could you please give me your email ID so that I can mail it to you. Thanks in advance.
Old   February 1, 2019, 07:58
There are regions in there which are not solved. Files which set up the regions without them being used etc. Please clean this up, that makes it difficult to tell what is used and what isn't. The only files which should add to the file size are
A the files inside polyMesh except the boundary file and the cellToRegion files. Please add the boundary files since without them it is difficult to tell what your mesh boundary coupling looks like
Old   February 4, 2019, 06:30
Shiromani Chandra
Hey Bloerb,
Sorry for my late reply as I could not log in due to some personal issues. I am attaching the updated case folder( very sorry as I dint post the case properly last time). Kindly help.
When I run the case following error comes:
bash: source: /opt/openfoam5/bin/: is a directory
openfoam@openfoam-VirtualBox:~/Desktop/planewall/FlowPastCell1$ ./Allclean
Cleaning /home/openfoam/Desktop/planewall/FlowPastCell1 case
openfoam@openfoam-VirtualBox:~/Desktop/planewall/FlowPastCell1$ ./Allrun
Exec : ideasUnvToFoam Mesh_nointface1.unv
Date : Feb 04 2019
Time : 16:50:35
PID : 3416
I/O : uncollated
Case : /home/openfoam/Desktop/planewall/FlowPastCell1
nProcs : 1
Create time
Processing tag:164
Starting reading units at line 3.
l:1
units:" SI: Meter (newton)"
unitType:2
Unit factors:
Length scale : 1
Force scale : 1
Temperature scale : 1
Temperature offset : 273.15
Processing tag:2420
Skipping tag 2420 on line 9
Skipping section at line 9.
Processing tag:2411
Starting reading points at line 20.
Read 10421 points.
Processing tag:2412
Starting reading cells at line 20865.
First occurrence of element type 11 for cell 1 at line 20866
First occurrence of element type 41 for cell 265 at line 21658
First occurrence of element type 111 for cell 5325 at line 31778
Read 60088 cells and 5060 boundary faces.
Processing tag:2467
Starting reading patches at line 151956.
For group 1 named Cell trying to read 17520 patch face indices.
For group 2 named Inlet trying to read 84 patch face indices.
For group 3 named Domain trying to read 42568 patch face indices.
For group 4 named Outlet trying to read 84 patch face indices.
For group 5 named Walls trying to read 416 patch face indices.
For group 6 named CellSurf trying to read 4476 patch face indices.
Of 5060 so-called boundary faces 4476 belong to two cells and are therefore internal
Sorting boundary faces according to group (patch)
0: Cell is cellZone
1: Inlet is patch
2: Domain is cellZone
3: Outlet is patch
4: Walls is patch
5: CellSurf is faceZone
Constructing mesh with non-default patches of size:
Inlet 84
Outlet 84
Walls 416
Adding cell and face zones
Cell Zone Domain 42568
Cell Zone Cell 17520
Face Zone CellSurf 4476
End
Exec : splitMeshRegions -cellZonesOnly -overwrite
Date : Feb 04 2019
Time : 16:50:41
PID : 3418
I/O : uncollated
nProcs : 1
Create time
Create mesh for time = 0
Creating single patch per inter-region interface.
Using current cellZones to split mesh into regions. This requires all cells to be in one and only one cellZone.
Number of regions:2
Writing region per cell file (for manual decomposition) to "/home/openfoam/Desktop/planewall/FlowPastCell1/constant/cellToRegion"
Writing region per cell as volScalarField to "/home/openfoam/Desktop/planewall/FlowPastCell1/0/cellToRegion"
Region Cells
0 42568
1 17520
Region Zone Name
0 0 Domain
1 1 Cell
Sizes of interfaces between regions:
Interface Region Region Faces
0 0 1 4476
Reading volScalarField cellToRegion
Reading volScalarField p
Reading volScalarField T
Reading volScalarField k
Reading volScalarField epsilon
Reading volScalarField p_rgh
Reading volVectorField U
Adding patches
Adding patches
For interface between region Domain and Cell added patches
3 Domain_to_Cell
4 Cell_to_Domain
Region 0
Creating mesh for region 0 Domain
Testing:"/home/openfoam/Desktop/planewall/FlowPastCell1/system/Domain/fvSchemes"
Mapping fields
Mapping field cellToRegion
Mapping field k
Mapping field p_rgh
Mapping field p
Mapping field T
Mapping field epsilon
Mapping field U
Deleting empty patches
Writing new mesh
Writing addressing to base mesh
Writing map pointRegionAddressing from region0 points back to base mesh.
Writing map faceRegionAddressing from region0 faces back to base mesh.
Writing map cellRegionAddressing from region0 cells back to base mesh.
Writing map boundaryRegionAddressing from region0 boundary back to base mesh.
Region 1
Creating mesh for region 1 Cell
Testing:"/home/openfoam/Desktop/planewall/FlowPastCell1/system/Cell/fvSchemes"
Mapping fields
Mapping field k
Mapping field p_rgh
Mapping field p
Mapping field T
Mapping field U
Writing new mesh
Writing map pointRegionAddressing from region1 points back to base mesh.
Writing map faceRegionAddressing from region1 faces back to base mesh.
Writing map cellRegionAddressing from region1 cells back to base mesh.
Writing map boundaryRegionAddressing from region1 boundary back to base mesh.
End
Date : Feb 04 2019
Time : 16:50:44
PID : 3423
I/O : uncollated
nProcs : 1
Create time
type heRhoThermo;
transport const;
thermo hConst;
equationOfState rhoConst;
specie specie;
Adding to rhoFluid
Adding to UFluid
Adding to phiFluid
Adding to gFluid
Adding to hRefFluid
Adding to ghFluid
Adding to ghfFluid
Adding to turbulence
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
Selecting radiationModel none
Adding MRF
No MRF models present
Adding fvOptions
No finite volume options present
*** Reading solid mesh thermophysical properties for region Cell
Adding to thermos
type heSolidThermo;
transport constIso;
thermo hConst;
specie specie;
Adding to radiations
Adding fvOptions
Time = 1
Solving for fluid region Domain
--> FOAM FATAL ERROR:
cannot be called for a calculatedFvPatchField
on patch Walls of field U in file "/home/openfoam/Desktop/planewall/FlowPastCell1/0/Domain/U"
You are probably trying to solve for a field with a default boundary condition.
From function Foam::tmp<Foam::Field<Type> > Foam::calculatedFvPatchField<Type>::gradientIntern alCoeffs() const [with Type = Foam::Vector<double>]
in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 187.
FOAM aborting
#1 Foam::error::abort() at ??:?
#2 Foam::calculatedFvPatchField<Foam::Vector<double> >::gradientInternalCoeffs() const at ??:?
#3 Foam::fv::gaussLaplacianScheme<Foam::Vector<double >, Foam::SymmTensor<double> >::fvmLaplacianUncorrected(Foam::GeometricField<do uble, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#4 Foam::fv::gaussLaplacianScheme<Foam::Vector<double >, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#5 Foam::fv::laplacianScheme<Foam::Vector<double>, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#6 Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::laplacian<Foam::Vector<double>, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) at ??:?
#7 Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::laplacian<Foam::Vector<double>, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#8 Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::laplacian<Foam::Vector<double>, double>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#9 Foam::linearViscousStress<Foam::laminarModel<Foam: :ThermalDiffusivity<Foam::CompressibleTurbulenceMo del<Foam::fluidThermo> > > >::divDevRhoReff(Foam::GeometricField<Foam::Vector <double>, Foam::fvPatchField, Foam::volMesh>&) const at ??:?
#10 ? at ??:?
#11 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#12 ? at ??:?
Aborted (core dumped)
Old   February 4, 2019, 17:01
Nearly all your boundary conditions are wrong.
  1. You can not impose the velocity on inlet AND outlet. Set the outlet to zeroGradient!
  2. Only specify p_rgh and set p to calculated everywhere
  3. Change the inlet and outlet boundary conditions for k and epsilon
  4. and you need to use changeDictionary afer splitting the mesh.
shiromaniac likes this.
Old   February 7, 2019, 06:02
Post
Shiromani Chandra
Hey Bloerb,
I am really thankful to you for having a look at my case. Because of you I was finally able to run it by keeping the Cell(the Solid) at a constant temperature of 400K. Now that i have run the case, my supervisor has asked me to add a constant heat generation source inside the cell. Could you please help me out with that??
Regards,
Shiromani
Old   February 7, 2019, 07:46
Add an fvOption file to your region folder. Either constant/cell oder system/cell depending on your OF version.
|  \\    /   O peration     | Version:  dev                                   |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system/cell";
    object      fvOptions;
options
    energySource
        type            scalarSemiImplicitSource;
        selectionMode   all; // or only part of the domain via a cellZone e.g defined with topoSet
        volumeMode      specific; // source term per volume or total
        injectionRateSuSp
            h      (1.5e6 0);   // explicit and implicit part of the source term
This adds a temperature independent source term in either W or W/m³ depending on the volumeMode. The second number in the injectionRateSuSp(here 0) would be the implicit part and hence the temperature dependent one.
Old   February 13, 2019, 02:04
Shiromani Chandra
Hey Bloerb,
Thank you so much for all the knowledge you shared with me. I have one more doubt. What should I keep my interface boundary conditions for the region Cell? As of now I have the following interface conditions:
| \\ / O peration | Version: 2.1.x |
FoamFile
version 2.0;
format ascii;
class dictionary;
object changeDictionaryDict;
T
internalField uniform 300;
boundaryField
Cell_to_Domain
type compressible::turbulentTemperatureCoupledBaffleMix ed;
Tnbr T;
kappaMethod solidThermo;
kappaName none;
value uniform 300;
Old   March 27, 2021, 18:36
Exclamation chtmultiregionsimplefoam not computing
Anusha
Anushaa is on a distinguished road
Hi , I am trying to solve my simulation and I am stuck with this ...pls let me know what is the issue
Create time
Create fluid mesh for region waterchannel for time = 0
Create solid mesh for region baseplate for time = 0
*** Reading fluid mesh thermophysical properties for region waterchannel
type heRhoThermo;
transport const;
thermo hConst;
specie specie;
Adding to rhoFluid
Adding to UFluid
Adding to phiFluid
Adding to hRefFluid
Adding to ghFluid
Adding to ghfFluid
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
Adding MRF
Adding fvOptions
*** Reading solid mesh thermophysical properties for region baseplate
Adding to thermos
type heSolidThermo;
transport constIso;
thermo hConst;
specie specie;
Selecting radiationModel opaqueSolid
Selecting absorptionEmissionModel constantAbsorptionEmission
Selecting scatterModel none
Adding fvOptions
Time = 1
Solving for fluid region waterchannel
Anushaa is offline   Reply With Quote
Old   October 12, 2021, 08:26
Praharsha Reddy
lonewanderer is on a distinguished road
Hi Anusha,
what are your boundary conditions?
lonewanderer is offline   Reply With Quote
Old   October 18, 2021, 08:40
amol patel
amol_patel is on a distinguished road
Hi lonewanderer,
I have a similar problem while solving my case of shell and tube heat exchanger
Can you kindly check my thread "chtMultiRegionFoam solver stops without any error"
And if possible, help me please.
Thanks ,
amol.
amol_patel is offline   Reply With Quote
chtmultiregionfoam, chtmultiregionsimpefoam, openfoam, salome meshing
findCell() in parallel: not working if location is outside the domain TobiWol OpenFOAM 0 January 10, 2018 14:33
Processor 0 not working vishwesh OpenFOAM Running, Solving & CFD 0 November 17, 2017 03:35
Is the subsetMotionSolver working in parallel? Arnoldinho OpenFOAM Running, Solving & CFD 7 April 27, 2016 04:38
DPM parallel is not working but serial is working johnwinter FLUENT 1 March 27, 2012 02:01
Error: Unable to retrieve mon from working directo Atit Koonsrisuk CFX 6 February 20, 2004 05:07
