February 13, 2019, 13:26 |
Open-FOAM MRF & SRF case Set-up?
Hello Friends,
Currently, I am working to solve Turbulent flow simulation on a ROTATION MIXER, in which ROTOR is enclosed in an 18mm Fluid-Zone. To my Geometry, I have use HEX-Elements using Open-FOAM with 2.6 skewness, which I this it is a decent mesh setting to fully converge. I have a doubt!!! how to calculate the INTERNAL FIELD values for (Epsilon, K, P, U, and OMEGA) to set up? is that necessary to calculate to set-up the simulations? It would be a great help if someone explain me to set up this case file. Thank you. Last edited by Srinath Reddy; February 13, 2019 at 14:29. |
does Hyperthreading affect the application of UDF? | SJSW | Fluent UDF and Scheme Programming | 11 | October 10, 2018 22:28 |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
OpenFOAM 1.6.x - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 68 | April 22, 2013 11:03 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
