pressure drop
Old   March 16, 2019, 12:30
Question total pressure drop
regard is on a distinguished road
hi every one
i have a question about total pressure drop in open foam
my geometry is Vertical rectangular channel .The fluid moves from the bottom to upwards and wall is heated by constant heat flux and we have phase change in this channel....i calculate the pressure drop by following code
deltap
type patchExpression;
variables
"pout{patch'outlet}=sum(p*area())/sum(area());"
patches (
inlet
expression "p-pout";
accumulations (
average
verbose true;
outputControlMode timeStep;//outputTime;//
outputInterval 100;
but this answer is more less than Experimental data how can i calculate the total pressure loss in this case?(solver:PhaseChangeHeatFoam)
thanks in advance
regard is offline   Reply With Quote
Fluent cyclone pressure drop mkal FLUENT 1 February 20, 2020 00:55
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 05:35
Pressure drop using Fan type BC Alexis Sack OpenFOAM Running, Solving & CFD 2 September 22, 2014 09:18
How to study pressure drop of continous phase in VOF model sajeesh FLUENT 4 February 5, 2014 22:01
Pipe Flow - Pressure Drop Daniel L FLOW-3D 2 December 10, 2010 04:23
