Simulating continuous density stratified flow using interFoam
Old   August 31, 2023, 09:33
Default Simulating continuous density stratified flow using interFoam
chenyq
chenyq is on a distinguished road
Hi everyone,
greetings.
I am trying to simulate continuous density stratified flow(like seawater). I use the interFoam solver and initializ the internal field using codestream. I set the alpha in the field to vary linearly from 0 to 1 in the depth direction, with alpha=0 corresponding to rho=1000 and alpha=1 corresponding to rho=1030. Thus, the corresponding density varies from 1000 to 1030 from top to bottom, and the initial alpha field, initial density field, and boundary conditions are set as shown in the figure 1. Figure 1 shows T=0s.
Due to the absence of other disturbance conditions in the calculation area, the calculation results should not differ significantly from the initial field. But my simulation results showed that the alpha and density fields became disordered and gradually approached the situation of only two-phase flow (as shown in the figure 2 and figure 3). Figure 2 and figure 3 show T=10s and T=50s respectively.
I want to know if the interFoam solver can simulate continuous density stratified flow. and if so, how can I modify the relevant settings to improve the simulation results. If interFoam is not suitable for this type of problem, is there a better solution in OpenFoam.
Any help is appreciated!
chenyq is offline   Reply With Quote
SU2 incompressible laminar flow mkulcsar SU2 3 April 30, 2023 22:59
Ncrit for a glider Xfoil. How to use it. GPT4 answer AlanMattanó Main CFD Forum 0 April 10, 2023 12:16
Visualising Compressible Flow s34n Main CFD Forum 0 October 23, 2022 13:53
Gravity/Buoyancy/Buoyancy reference density in two phase flow sharifi CFX 10 June 9, 2014 10:23
interFoam and stratified flow in a pipeline AlmostSurelyRob OpenFOAM 1 February 24, 2011 18:23
