March 28, 2019, 07:26 |
Problems about oscillatingRotatingMotion
Chen
Rep Power: 7 |
hello,guys
I am new to dynamic mesh, and now i am working on a case that needs to use oscillatingRotatingMotion . But it only can achieve the sine function.So how can i make it to cosine function? |
March 16, 2023, 03:57 |
Gengatharan.R
sir crescendo...
did you find the answer to that question regarding the conversion of sin to cos in oscillatingrotatingmotoin? |
March 16, 2023, 08:17 |
#3 | |
Amirhossein Taran
Rep Power: 9 |
Take a look at ORM, create a new class base on the original ORM, Change the formulation, and compile your library, finally just import it into your dynamicMeshDict and it must work. Bests, Amirhossein |
March 19, 2023, 09:48 |
Sanjay R
Rep Power: 3 |
Dear Amirhossein and anyone who'd want to help,
As we are new to compilation of the library, we did face issues with it. For the objective, we renamed the oscillatingRotatingMotion.C and .H files to my_oscillatingRotatingMotion.C and .H and also anywhere the class name is called. In the Make directory, the "files" contain the EXE mention to the my_oscillatingRotatingMotion.C, and the "options" contain the lnInclude mention for dynamicMesh in EXE_INC. We aren't sure to what EXE_LIBS we must link, which we believe causes error when "wmake libso" is done. As we are new to this and have no experience with compilation, we could'nt figure out the error and are asking for guidance... The case is attached with the post. |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[mesh manipulation] Problems with rotational cyclic boundaries | TReviol | OpenFOAM Meshing & Mesh Conversion | 8 | July 11, 2014 03:45 |
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 06:44 |
Two-phase air water flow problems by activating Wall Lubrication Force | challenger85 | CFX | 5 | November 5, 2009 05:44 |
Help required to solve Hydraulic related problems | aero | CFX | 0 | October 30, 2006 11:00 |
