[foam-extend.org] Problems compiling foam-extend-4.0 + fsiFoam on Ubuntu+WSL |
April 15, 2019, 18:52 |
Justine
Rep Power: 7 |
I have read dozens of threads on this, but cannot find a fix to get any of the three tutorials to run in fsiFoam on foam-extend-4.0.
For example, after following the intructions here (https://openfoamwiki.net/index.php/E...oam-extend_3.0) to run the tutorial HronTurekFsi3, I get the following output: Code:
Running blockMesh on /home/jbrakefi/foam/jbrakefi-4.0/FluidSolidInteraction/run/fsiFoam/HronTurekFsi3/fluid Running setSet on /home/jbrakefi/foam/jbrakefi-4.0/FluidSolidInteraction/run/fsiFoam/HronTurekFsi3/fluid Running setsToZones on /home/jbrakefi/foam/jbrakefi-4.0/FluidSolidInteraction/run/fsiFoam/HronTurekFsi3/fluid Running blockMesh on /home/jbrakefi/foam/jbrakefi-4.0/FluidSolidInteraction/run/fsiFoam/HronTurekFsi3/fluid Running setSet on /home/jbrakefi/foam/jbrakefi-4.0/FluidSolidInteraction/run/fsiFoam/HronTurekFsi3/fluid Running setsToZones on /home/jbrakefi/foam/jbrakefi-4.0/FluidSolidInteraction/run/fsiFoam/HronTurekFsi3/fluid /bin/sh: 1: /home/jbrakefi/foam/foam-extend-4.0/wmake/bin/linux64Gcc/wmkdep: not found SOURCE=hronTurekReport.C ; g++ -m64 -Dlinux64 -DWM_DP -Wno-deprecated -Wall -Wextra -Wno-unused-parameter -Wnon-virtual-dtor -Wunused-local-typedefs -Werror -Wredundant-decls -Wcast-align -Wmissing-declarations -Wswitch-enum -Winvalid-pch -Wredundant-decls -Wformat=2 -Wmissing-format-attribute -Wformat-nonliteral -O3 -DNoRepository -ftemplate-depth-200 -std=c++11 -I/home/jbrakefi/foam/jbrakefi-4.0/FluidSolidInteraction/src/fluidSolidInteraction/lnInclude -I/home/jbrakefi/foam/jbrakefi-4.0/FluidSolidInteraction/src/ThirdParty/eigen3 -I/home/jbrakefi/foam/foam-extend-4.0/src/finiteVolume/lnInclude -I/home/jbrakefi/foam/foam-extend-4.0/src/finiteArea/lnInclude -I/home/jbrakefi/foam/foam-extend-4.0/src/meshTools/lnInclude -I/home/jbrakefi/foam/foam-extend-4.0/src/dynamicMesh/dynamicFvMesh/lnInclude -I/home/jbrakefi/foam/foam-extend-4.0/src/lagrangian/basic/lnInclude -IlnInclude -I. -I/home/jbrakefi/foam/foam-extend-4.0/src/foam/lnInclude -I/home/jbrakefi/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/hronTurekReport.o In file included from hronTurekReport.C:29:0: hronTurekReport.H:41:28: fatal error: functionObject.H: No such file or directory compilation terminated. hronTurekReport.dep:3: recipe for target 'Make/linux64GccDPOpt/hronTurekReport.o' failed make: *** [Make/linux64GccDPOpt/hronTurekReport.o] Error 1 Running fsiFoam on /home/jbrakefi/foam/jbrakefi-4.0/FluidSolidInteraction/run/fsiFoam/HronTurekFsi3/fluid The 3dTube doesn't give me an error but seems to do nothing. When I open the log.fsiFoam, it reads "./Allrun: 55: ./Allrun: fsiFoam: not found" |
April 15, 2019, 19:24 |
Installing foam-extend-4.0 on Ubuntu on Windows
Justine
Rep Power: 7 |
I may not have installed/compiled foam-extend-4.0 correctly. I followed the instructions here: https://openfoamwiki.net/index.php/I...u#Ubuntu_16.04
These instructions seem incomplete when compared to that of installing on Linux: https://openfoamwiki.net/index.php/I...oam-extend-4.0 What instructions do I need to follow? I tried running a tutorial on fe4.0 and it was missing an ./Allrun and I couldn't even get blockMesh to work. |
April 15, 2019, 20:12 |
#3 | |
Daniel
Rep Power: 21 |
Those links you have posted are complementary. The first link contains prerequisites that are needed before heading to the second link which actually contain the instruction to compile foam-extend-4.0. I think you have not compiled the source code yet, refer to section 1.2 which describe everything step by step. |
April 15, 2019, 23:34 |
Justine
Rep Power: 7 |
Thank you for the reply. I got up until the ./Allwmake.firstInstall, and it seems stuck on the following with no indication as to how long it will take. If more than an hour goes by, should I kill it and start over or try to find what went wrong?
make: Nothing to be done for 'all'. This system rpm command: rpm --force-debian ======================================== Starting ThirdParty Allwmake.pre ======================================== This system rpm command: rpm --force-debian ======================================== Starting ThirdParty AllMake: Stage1 ======================================== Building bison 2.7 Package name : bison-2.7 Package URL : http://ftpmirror.gnu.org/bison/bison-2.7.tar.gz RPM spec file name: bison-2.7.spec RPM file name : Additional flags : Updating the ThirdParty environment variables before building package bison-2.7 RPM file name : /home/jbrakefi/foam/foam-extend-4.0/ThirdParty/rpmBuild/RPMS/x86_64/bison-2.7-linux64GccDPOpt.x86_64.rpm Making package bison-2.7 using RPM. Building package bison-2.7 using SPEC file : bison-2.7.spec. Optional args: |
April 16, 2019, 11:00 |
#5 | |
Daniel
Rep Power: 21 |
Could you post the complete build log? It takes less than an hour on my PC to build Third-party utilities + foam-extend source code with eight 4.0GHz cores. |
April 16, 2019, 13:12 |
Justine
Rep Power: 7 |
What is a complete build log and how to I find it? I left it going overnight but seems to have made no progress and is still stuck on "Building package bison-2.7 using SPEC file : bison-2.7.spec. Optional args:"
April 16, 2019, 14:21 |
Justine
Rep Power: 7 |
For now, I am attempting to run ./Allwmake since maybe the "first time" can't be run again after it fails. Should I have tried ./Allclean first?
It has been running for a while now (~30 minutes) but at least it is doing things and printing to the terminal. I am also looking into installing the Windows version. I am using Windows 10, and since previously I was using OpenFoam standard I could not run it directly on Windows and instead have been using the Bash on Ubuntu on Windows. |
April 16, 2019, 17:53 |
Still Stuck
Justine
Rep Power: 7 |
It looks like installing on Windows won't be any easier, and the instructions for that (https://openfoamwiki.net/index.php/I...oam-extend-4.0) mention that it isn't "fully tested or validated". Is it worth my time trying this route?
Looking through the tutorial cases in foam-extend-4.0, why are no ./Allrun files included? There's one ./Allrun in the root of tutorials. How are you supposed to run these? I still think I did not compile correctly, because if I try "blockMesh" inside any of the tutorials, it says command not found. |
April 17, 2019, 15:56 |
#9 |
Justine
Rep Power: 7 |
Is there a way to start over and remove foam-extend and fsiFoam, neither of which are working? I don't know if simply deleting all the files will work, but using ./Allclean gives this output:
./Allclean: line 2: rmdepall: command not found ./Allclean: line 3: wcleanLnIncludeAll: command not found |
April 17, 2019, 16:49 |
#10 |
Andrew O. Winter
Rep Power: 10 |
Based on the fact that wcleanLnIncludeAll isn't working, I'm wondering if you maybe forgot to source the foam-extend-4.0 bashrc file before executing the ./Allclean command?
April 18, 2019, 13:52 |
#11 |
Justine
Rep Power: 7 |
I got the ./Allclean command to work now, but still cannot get ./Allwmake.firstInstall to get beyond "Building package bison-2.7 using SPEC file : bison-2.7.spec. Optional args:".
How do I truly get rid of everything and start fresh? |
April 18, 2019, 14:56 |
#13 |
Justine
Rep Power: 7 |
I deleted everything and tried from the beginning. After I got to "./Allwmake.firstInstall" things seemed at first to go better, as I got more output, but it also stopped after a while with no indication as to how long it will be stuck:
gcc -m64 -Wall -O3 -fPIC dirToString.c -o /home/jbrakefi/foam/foam-extend-4.0/wmake/bin/linux64Gcc/dirToString flex wmkdep.l gcc -m64 -Wall -O3 -fPIC lex.yy.c -o /home/jbrakefi/foam/foam-extend-4.0/wmake/bin/linux64Gcc/wmkdep lex.yy.c:1406:17: warning: ‘yyunput’ defined but not used [-Wunused-function] static void yyunput (int c, char * yy_bp ) ^ lex.yy.c:1449:16: warning: ‘input’ defined but not used [-Wunused-function] static int input (void) ^ This system rpm command: rpm --force-debian ======================================== Starting ThirdParty Allwmake.pre ======================================== This system rpm command: rpm --force-debian ======================================== Starting ThirdParty AllMake: Stage1 ======================================== Building bison 2.7 Package name : bison-2.7 Package URL : http://ftpmirror.gnu.org/bison/bison-2.7.tar.gz RPM spec file name: bison-2.7.spec RPM file name : Additional flags : Updating the ThirdParty environment variables before building package bison-2.7 RPM file name : /home/jbrakefi/foam/foam-extend-4.0/ThirdParty/rpmBuild/RPMS/x86_64/bison-2.7-linux64GccDPOpt.x86_64.rpm Download bison-2.7.tar.gz from : http://ftpmirror.gnu.org/bison/bison-2.7.tar.gz --2019-04-18 11:42:49-- http://ftpmirror.gnu.org/bison/bison-2.7.tar.gz Resolving ftpmirror.gnu.org (ftpmirror.gnu.org)... 209.51.188.200, 2001:470:142:5::200 Connecting to ftpmirror.gnu.org (ftpmirror.gnu.org)|209.51.188.200|:80... connected. HTTP request sent, awaiting response... 302 Moved Temporarily Location: http://ftp.wayne.edu/gnu/bison/bison-2.7.tar.gz [following] --2019-04-18 11:42:50-- http://ftp.wayne.edu/gnu/bison/bison-2.7.tar.gz Resolving ftp.wayne.edu (ftp.wayne.edu)... 141.217.0.199 Connecting to ftp.wayne.edu (ftp.wayne.edu)|141.217.0.199|:80... connected. HTTP request sent, awaiting response... 200 OK Length: 3137885 (3.0M) [application/x-gzip] Saving to: ‘bison-2.7.tar.gz’ bison-2.7.tar.gz 100%[=================================================>] 2.99M 805KB/s in 3.8s 2019-04-18 11:42:54 (805 KB/s) - ‘bison-2.7.tar.gz’ saved [3137885/3137885] Making package bison-2.7 using RPM. Building package bison-2.7 using SPEC file : bison-2.7.spec. Optional args: tools/makeThirdPartyFunctionsForRPM: line 163: 30204 Segmentation fault (core dumped) rpmbuild --define "_topdir $buildBase" --dbpath $buildBase/rpmDB -bb ./SPECS/$specFile "$@" Installing package: bison-2.7 Uninstalling bison-2.7 using RPM: bison-2.7-linux64GccDPOpt.x86_64 Installing bison-2.7 using RPM file: /home/jbrakefi/foam/foam-extend-4.0/ThirdParty/rpmBuild/RPMS/x86_64/bison-2.7-linux64GccDPOpt.x86_64.rpm error: open of /home/jbrakefi/foam/foam-extend-4.0/ThirdParty/rpmBuild/RPMS/x86_64/bison-2.7-linux64GccDPOpt.x86_64.rpm failed: No such file or directory Done installing package ======================================== Done ThirdParty AllMake: Stage1 ======================================== This system rpm command: rpm --force-debian ======================================== Starting ThirdParty AllMake: Stage2 ======================================== Building openmpi 1.8.8 Package name : openmpi-1.8.8 Package URL : http://www.open-mpi.org/software/ompi/v1.8/downloads/openmpi-1.8.8.tar.gz RPM spec file name: openmpi-1.8.8.spec RPM file name : Additional flags : --define Updating the ThirdParty environment variables before building package openmpi-1.8.8 RPM file name : /home/jbrakefi/foam/foam-extend-4.0/ThirdParty/rpmBuild/RPMS/x86_64/openmpi-1.8.8-linux64GccDPOpt.x86_64.rpm Download openmpi-1.8.8.tar.gz from : http://www.open-mpi.org/software/ompi/v1.8/downloads/openmpi-1.8.8.tar.gz --2019-04-18 11:42:54-- http://www.open-mpi.org/software/ompi/v1.8/downloads/openmpi-1.8.8.tar.gz Resolving www.open-mpi.org (www.open-mpi.org)... 192.185.39.252 Connecting to www.open-mpi.org (www.open-mpi.org)|192.185.39.252|:80... connected. HTTP request sent, awaiting response... 302 Found Location: https://www.open-mpi.org/software/ompi/v1.8/downloads/openmpi-1.8.8.tar.gz [following] --2019-04-18 11:42:54-- https://www.open-mpi.org/software/ompi/v1.8/downloads/openmpi-1.8.8.tar.gz Connecting to www.open-mpi.org (www.open-mpi.org)|192.185.39.252|:443... connected. HTTP request sent, awaiting response... 301 Moved Permanently Location: https://download.open-mpi.org/release/open-mpi/v1.8/openmpi-1.8.8.tar.gz [following] --2019-04-18 11:42:55-- https://download.open-mpi.org/release/open-mpi/v1.8/openmpi-1.8.8.tar.gz Resolving download.open-mpi.org (download.open-mpi.org)... 99.84.239.72, 99.84.239.96, 99.84.239.75, ... Connecting to download.open-mpi.org (download.open-mpi.org)|99.84.239.72|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 19718799 (19M) [application/x-tar] Saving to: ‘openmpi-1.8.8.tar.gz’ openmpi-1.8.8.tar.gz 100%[=================================================>] 18.80M 48.4MB/s in 0.4s 2019-04-18 11:42:55 (48.4 MB/s) - ‘openmpi-1.8.8.tar.gz’ saved [19718799/19718799] Making package openmpi-1.8.8 using RPM. Building package openmpi-1.8.8 using SPEC file : openmpi-1.8.8.spec. Optional args: --define _configureAdditionalArgs "$WM_THIRD_PARTY_USE_OPENMPI_188_ConfigureAdditionalArgs" |
April 18, 2019, 15:45 |
#14 |
Andrew O. Winter
Rep Power: 10 |
How long has your system been trying to compile OpenMPI? Based on FAQ Item 37 in this openmpi.org FAQ list, it seems like compiling OpenMPI may take a long time for compiling things using the F90 fortran standard.
April 18, 2019, 15:58 |
#15 |
Justine
Rep Power: 7 |
One hour later, still going.
April 19, 2019, 16:49 |
Similar Problems on Bash on Windows
#16 |
Justine
Rep Power: 7 |
I have had the same kinds of issues as on this thread, and so I'm hoping someone can help me finally get foam-extend-4.0 running on my bash on ubuntu on windows subsystem.
Sometimes it gets stuck on Stage 1 while building package bison-2.7, but if I delete everything and start over, it gets stuck on Stage 2 building package openmpi-1.8.8: Code:
======================================== Starting ThirdParty AllMake: Stage2 ======================================== Building openmpi 1.8.8 Package name : openmpi-1.8.8 Package URL : http://www.open-mpi.org/software/ompi/v1.8/downloads/openmpi-1.8.8.tar.gz RPM spec file name: openmpi-1.8.8.spec RPM file name : Additional flags : --define Updating the ThirdParty environment variables before building package openmpi-1.8.8 RPM file name : /home/jbrakefi/foam/foam-extend-4.0/ThirdParty/rpmBuild/RPMS/x86_64/openmpi-1.8.8-linux64GccDPOpt.x86_64.rpm Download openmpi-1.8.8.tar.gz from : http://www.open-mpi.org/software/ompi/v1.8/downloads/openmpi-1.8.8.tar.gz --2019-04-19 13:44:58-- http://www.open-mpi.org/software/ompi/v1.8/downloads/openmpi-1.8.8.tar.gz Resolving www.open-mpi.org (www.open-mpi.org)... 192.185.39.252 Connecting to www.open-mpi.org (www.open-mpi.org)|192.185.39.252|:80... connected. HTTP request sent, awaiting response... 302 Found Location: https://www.open-mpi.org/software/ompi/v1.8/downloads/openmpi-1.8.8.tar.gz [following] --2019-04-19 13:44:59-- https://www.open-mpi.org/software/ompi/v1.8/downloads/openmpi-1.8.8.tar.gz Connecting to www.open-mpi.org (www.open-mpi.org)|192.185.39.252|:443... connected. HTTP request sent, awaiting response... 301 Moved Permanently Location: https://download.open-mpi.org/release/open-mpi/v1.8/openmpi-1.8.8.tar.gz [following] --2019-04-19 13:44:59-- https://download.open-mpi.org/release/open-mpi/v1.8/openmpi-1.8.8.tar.gz Resolving download.open-mpi.org (download.open-mpi.org)... 13.32.252.196, 13.32.252.3, 13.32.252.178, ... Connecting to download.open-mpi.org (download.open-mpi.org)|13.32.252.196|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 19718799 (19M) [application/x-tar] Saving to: ‘openmpi-1.8.8.tar.gz’ openmpi-1.8.8.tar.gz 100%[=================================================>] 18.80M 46.2MB/s in 0.4s 2019-04-19 13:45:00 (46.2 MB/s) - ‘openmpi-1.8.8.tar.gz’ saved [19718799/19718799] Making package openmpi-1.8.8 using RPM. Building package openmpi-1.8.8 using SPEC file : openmpi-1.8.8.spec. Optional args: --define _configureAdditionalArgs "$WM_THIRD_PARTY_USE_OPENMPI_188_ConfigureAdditionalArgs" Code:
export WM_THIRD_PARTY_USE_BISON_27=1 export QT_BIN_DIR=/path/to/qmake_directory export QT_BIN_DIR=/usr/bin/ |
April 22, 2019, 16:54 |
#17 |
Justine
Rep Power: 7 |
After installing both bison and openmpi manually, it gets stuck at the very next installation in Stage 3, which is metis.
It always gets stuck after "Building package metis-5.1.0 using SPEC file : metis-5.1.0.spec. Optional args:" So this is not an issue with an individual package. How do I troubleshoot why it always gets stuck at "Optional args:"?? |
April 22, 2019, 17:49 |
#18 |
Tom
Rep Power: 7 |
Hi JBrake,
I will start by saying that I am no expert, and got mine to work mostly through random guessing. Here are some things that I might suggest to try, in no particular order:
If those suggestions don't do it for you, I'm afraid I am out of options. Maybe we will get graced by Wyldcat and he can help you debug further. |
April 22, 2019, 19:56 |
#19 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick request @JBrake: I need to know the exact Ubuntu version you are using. Please run the following command:
cat /etc/lsb-release edit: Furthermore, if the link in the first post was correct, then the original issue seemed to be because the wrong version of the FSI toolkit (meant for foam-extend 3.0) was being used with foam-extend 4.0...
April 22, 2019, 20:20 |
#20 |
Justine
Rep Power: 7 |
I am using Ubuntu 16.04 on Bash on Windows (subsystem).
foam-extend 4.0, fsifoam |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[CGNS] CGNS converters available | mbeaudoin | OpenFOAM Meshing & Mesh Conversion | 137 | December 14, 2018 04:20 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
[Other] cgnsToFoam problems with "QUAD_4" cells | lentschi | OpenFOAM Meshing & Mesh Conversion | 1 | March 9, 2011 04:49 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
