Flow over terrain instability of OF by pressure profiles
Old   April 16, 2019, 05:05
Default Flow over terrain instability of OF by pressure profiles
Chris Schäfer
Chris123 is on a distinguished road
Dear all,
I have more or less a generic question hope to find someone who has experience with that.
I simulate flow over a terrain, it works for incompressible as well as for compressible in steadystate and transient ( here I use (simple -and pimpleFoam, rhosimple- and rhopimpleFoam respectively).
My U-inlet is a U-Profile (vs height). I set total pressure (single value) at the other side for pressure BC outlet.
However if I try use a pressure profile (vs height) then it always crases. Currently I’am not able to run rhosimpleFoam successfully, after 3s, I got the error Message FOAM FATAL ERROR: [1] Negative initial temperature T0: -234.778. (Of course I read a lot of threads about this error messages without solution.)
No matter what I put on the other sides on the BC and I also played around with fv solution fv sceme entries as well as with fine and coarse meshes. It doesn't work at all. I have the feeling that the more I specify (in the BC) the more problems I got (e.g if I put pressure profiles at al 4 Boundary sides or when I try to use also temperature profiles as BC…) .
I heard that OF becomes instable in general if I specify pressure profiles at the BC. Can someone confirm this?
Chris123 is offline   Reply With Quote
Pressure Driven Supersonic Flow in Converging-Diverging Nozzle cdm OpenFOAM Running, Solving & CFD 7 August 28, 2019 01:37
pulsatile blood flow - developing larger pressure in the fluid domain KushalJ CFX 4 April 29, 2015 00:14
Mass flow inlet and pressure outlet issue nikhil FLUENT 5 December 11, 2013 12:30
pressure gradient term in low speed flow Atit Koonsrisuk Main CFD Forum 2 January 10, 2002 10:52
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
