July 9, 2019, 07:51 |
pimpleFoam suddenly get exit
Milan
Rep Power: 9 |
Hi everyone,
I have been trying to run the pimpleFoam into my propeller case but there has been some error on executing the pimpleFoam after some minutes of execution. Code:
PIMPLE: Iteration 1 AMI: Creating addressing and weights between 37933 source faces and 37933 target faces AMI: Patch source sum(weights) min/max/average = 0.802181, 2.00213, 1.00903 AMI: Patch target sum(weights) min/max/average = 0.000569305, 2.01386, 1.0088 GAMG: Solving for pcorr, Initial residual = 1, Final residual = 0.00652399, No Iterations 3 time step continuity errors : sum local = 3.64691e-10, global = 1.50977e-11, cumulative = -2.62063e-09 smoothSolver: Solving for Ux, Initial residual = 0.000880174, Final residual = 7.935e-07, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.000120996, Final residual = 1.37146e-07, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.000929456, Final residual = 6.0459e-07, No Iterations 1 GAMG: Solving for p, Initial residual = 0.0059716, Final residual = 3.85954e-05, No Iterations 4 time step continuity errors : sum local = 5.12401e-11, global = 1.72928e-11, cumulative = -2.60334e-09 GAMG: Solving for p, Initial residual = 0.00229053, Final residual = 4.39153e-07, No Iterations 6 time step continuity errors : sum local = 5.94828e-13, global = 1.61902e-13, cumulative = -2.60317e-09 PIMPLE: Iteration 2 smoothSolver: Solving for Ux, Initial residual = 0.000274223, Final residual = 2.82053e-07, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 3.76589e-05, Final residual = 4.82803e-08, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.000326422, Final residual = 2.12023e-07, No Iterations 1 GAMG: Solving for p, Initial residual = 0.00601082, Final residual = 3.15255e-05, No Iterations 4 time step continuity errors : sum local = 4.2683e-11, global = -1.4213e-11, cumulative = -2.61739e-09 GAMG: Solving for p, Initial residual = 0.00213069, Final residual = 5.31767e-07, No Iterations 6 time step continuity errors : sum local = 7.03291e-13, global = -1.76353e-13, cumulative = -2.61756e-09 smoothSolver: Solving for epsilon, Initial residual = 1.84801e-05, Final residual = 6.1009e-08, No Iterations 1 smoothSolver: Solving for k, Initial residual = 4.95208e-05, Final residual = 1.68352e-07, No Iterations 1 ExecutionTime = 803.14 s ClockTime = 803 s forces forces write: sum of forces: pressure : (-2.94193 36.0195 -30.8047) viscous : (-0.0142583 -0.0344043 -0.0187688) porous : (0 0 0) sum of moments: pressure : (-0.341646 -29.0562 -3.71919) viscous : (4.3322e-05 -0.0234912 0.00595161) porous : (0 0 0) Courant Number mean: 0.000539523 max: 0.998274 deltaT = 3.63716e-06 Time = 0.000137992 PIMPLE: Iteration 1 AMI: Creating addressing and weights between 37933 source faces and 37933 target faces AMI: Patch source sum(weights) min/max/average = 0.796835, 2.02346, 1.00927 AMI: Patch target sum(weights) min/max/average = 0, 2.043, 1.00903 GAMG: Solving for pcorr, Initial residual = 1, Final residual = 0.00642757, No Iterations 3 time step continuity errors : sum local = 3.65445e-10, global = 1.45006e-11, cumulative = -2.60306e-09 smoothSolver: Solving for Ux, Initial residual = 0.000874066, Final residual = 7.71885e-07, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.00011986, Final residual = 1.32681e-07, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.000931321, Final residual = 5.87728e-07, No Iterations 1 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:? #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:? #5 ? at ??:? #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 ? at ??:? Floating point exception (core dumped) ***Max skewness = 7.68338, 60 highly skew faces I have been trying to run it in both serial and parallel but non of this work. Same problem reoccur. what could be the possible error to this? I don't know whether the problem arise because of skewness or something else. I am working in a project and there is no one to help me in OpenFOAM. This is only one option where I could ask for some help. Thank you. Best regards, |
ami, foam::error::printstack, pimplefoam |
delta T decreases suddenly in pimplefoam | 1988 | OpenFOAM Running, Solving & CFD | 10 | June 28, 2014 01:34 |
back pressure at exit for supersonic flow | BigFrank | FLUENT | 6 | April 24, 2014 15:13 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
Pressure drop and exit velocity | mejahan | CFX | 6 | August 4, 2013 16:57 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
