Initial Conditions to have pipe filled
Old   June 25, 2019, 11:54
Default Initial Conditions to have pipe filled
Suresh raja
sureshraja1 is on a distinguished road
I am using interFoam to predict the flow rate and time to drain out oil from a pipeline due to a rupture (may be modeled as an orifice). This is an incompressible flow but needs to be solved by first starting with the pipeline completely filled. Once a rupture occurs in the pipeline, the pump will be shut off. I am looking to predict the flow rate and the time to drain the liquids in the pipeline. The pipeline will also have variations in elevations that follow the terrain.
How would I set the initial conditions to have the pipeline filled with oil/liquid? There should be no incoming flow at t=0. At the initial time, the pipeline is filled completely (pressure = 1480 psig) and then see how long it will take to drain out due to the pipeline inclination (due to terrain)? I am not sure how to setup the initial condition "0" to satisfy this with the interFoam solver.
Thanks for your help!
sureshraja1 is offline   Reply With Quote
interfoam, openfoam, pipelines
Segmentation fault when using reactingFOAM for Fluids Tommy Floessner OpenFOAM Running, Solving & CFD 4 April 22, 2018 12:30
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 14:05
HeatSource BC to the whole region in chtMultiRegionHeater xsa OpenFOAM Running, Solving & CFD 3 November 7, 2016 05:07
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 04:13
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 12:50
