Oscillations in coefficients
Old   June 27, 2019, 01:45
Default Oscillations in coefficients
jawahar sivabharathy
sjsivabharathy is on a distinguished road
Hi all,
I'm using pisofoam to solve incompressible flow past multiple square cylinders at very low Reynolds number for Re < 150.
The maximum Courant number is 0.22.
I'm seeing oscillations in the time history of coefficients.
The flow seems ok.
Could someone suggest to me what should I do to aviod
such oscillations. I'm also showing below the controlDict, fvSchemes
and fvSolution file.
Thanks,
S Jawahar.
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 6
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application pisoFoam;
startFrom startTime;
startTime 186.790000000094494;
stopAt endTime;
//stopAt writeNow;
endTime 1000;
deltaT 0.001;
writeControl timeStep;
writeInterval 1000;
purgeWrite 0;
writeFormat ascii;
writePrecision 12;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
fvSchemes:
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default CrankNicolson 0.5;
ddt(phi) CrankNicolson 0.5;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) Gauss limitedLinearV 1;
div(phi,k) Gauss limitedLinear 1;
div(phi,epsilon) Gauss limitedLinear 1;
div(phi,omega) Gauss limitedLinear 1;
div(phi,R) Gauss limitedLinear 1;
div(R) Gauss linear;
div(phi,nuTilda) Gauss limitedLinear 1;
div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fvSolution:
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
p
solver GAMG;
tolerance 1e-06;
relTol 0.1;
smoother GaussSeidel;
pFinal
$p;
tolerance 1e-06;
relTol 0;
"(U|k|epsilon|omega|R|nuTilda)"
solver smoothSolver;
tolerance 1e-05;
relTol 0;
PISO
nCorrectors 3;
nNonOrthogonalCorrectors 0;
pRefCell 0;
pRefValue 0;
sjsivabharathy is offline   Reply With Quote
Antoine Equation coefficients for water Ludwig Prandtl CFX 4 May 20, 2025 10:24
[Other] Explain about the coefficients in the kOmegaSSTLM turbulence Model ht2017 OpenFOAM Community Contributions 2 April 23, 2020 03:55
Pressure distribution ok and wrong coefficients (Cl and Cd) Jeanp OpenFOAM Post-Processing 2 March 11, 2017 22:06
LES Time averaging Huge Oscillations Mirage OpenFOAM Programming & Development 1 January 27, 2017 10:20
A way to optimize the WENO scheme by optimizing the coefficients of linear scheme moon_light Main CFD Forum 1 November 27, 2012 09:19
