v2f turbulence model cannot predict boundary layer |
Gerd Fade
Rep Power: 11 ![]() |
Dear Foamers,
I am struggling with applying the basic v2f model (v1806) to simple flows, e.g. backward-facing step (low-Re) or Chow's wing testcase (high-Re). Below you can see the upper wall w/o step of the backward-facing step (BFS) and the suction side of Chow's wing both with SSTCC (Smirnov) and the v2f model. The problem is that the boundary layer does not develop properly with v2f. I tested a lot of different combinations of the boundary conditions without success. Here you see the BCs from the pitzDaily tutorial for the high-Re Case. backward-facing step: SSTCC: low-Re no slip condition with k: kLowReWallFunction omega: omegaWallFunction nut: nutLowReWallFunction ![]() v2f: low-Re no slip condition with k: kLowReWallFunction epsilon: epsilonWallFunction, lowReCorrection=on f: fWallFunction nut: nutUWallFunction (see source code: "turbulent viscosity wall function should be used") v2: v2WallFunction ![]() -------------------------- Chow's testcase: SST-CC: high-Re no slip condition with k: kqRWallFunction omega: omegaWallFunction nut: nutkWallFunction ![]() v2f: high-Re no slip condition with k: kqRWallFunction epsilon: epsilonWallFunction, lowReCorrection off f: fWallFunction nut: nutkWallFunction v2: v2WallFunction ![]() ----------------- Did you experience similar issues? And did you find a solution for it? Remark: Also asked here: Boundary Conditions for v2f turbulent model |
Display Modes | |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 05:39 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
errors | Fahad | Main CFD Forum | 0 | March 23, 2004 14:20 |
