July 19, 2019, 08:15 |
fsiFoam in foam extend 3.2 | Parallelization
GS
Rep Power: 10 |
Can anyone please help on running the fsiFoam solver in foam extend 3.2 on parallel processors.
I am trying on beamInCrossFlow case. Everything goes smooth on serial run. But on decomposing there seems a contradiction with 0/pointMotionU file. I get an error: Code:
Processor 0: field transfer --> FOAM FATAL ERROR: size of field = 233853 is not the same as the size of mesh = 231819 From function DimensionedField<Type, GeoMesh>::DimensionedField(const IOobject& io,const Mesh& mesh, const dimensionSet& dims, const Field<Type>& field) in file /home/iitmech4/foam/foam-extend-3.2/src/foam/lnInclude/DimensionedField.C at line 71. FOAM aborting I am searching for the bug for last many days but couldn't resolve. Also, I used foam extend-4.0 and its corresponding fsiFoam. There seems to be many bugs in that version. |
error with reactingFoam | BakedAlmonds | OpenFOAM Running, Solving & CFD | 4 | June 22, 2016 02:21 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
