Am getting very strange pressure/velocity problems at the inlet after a while |
July 25, 2019, 16:53 |
Andrei Cojocea
Rep Power: 6 |
Dear all,
I have been trying for a while now to simulate a 2D incompressible flow past a square cylinder using k-omega model and to obtain convergency. After creating the blockMesh and 0 files and system directories, I have managed to get the simulation started and it works fine for a while, but then it starts working wrong. |
July 25, 2019, 16:55 |
part_2
Andrei Cojocea
Rep Power: 6 |
Here are the rest of the files from OpenFoam.
Thank you very much. |
July 25, 2019, 17:18 |
Rep Power: 8 |
What is goining wrong?
July 25, 2019, 18:00 |
Andrei Cojocea
Rep Power: 6 |
First of all, thank you for your reply. I will upload some screenshots with the flow development for U,p and k in order to show you exactly what i get.
July 25, 2019, 18:51 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answers:
July 25, 2019, 19:01 |
Andrei Cojocea
Rep Power: 6 |
Ahhhh, i didn't think about total pressure. Thank you very much, I will start the simulation again, hopefully this time works.
In addition to my previous question, is it possible to define the inlet as a single patch? Instead of doing it block by block, just define the upper and lower edger for the whole inlet. |
July 25, 2019, 19:45 |
#7 | |
Bruno Santos
Rep Power: 128 |
Quick answers:
If you want to use only blockMesh... uh... Maybe use Blender with the SwiftBlock add-on? https://openfoamwiki.net/index.php/Contrib/SwiftBlock |
July 26, 2019, 18:48 |
Andrei Cojocea
Rep Power: 6 |
Thank you for your reply.
I have tried what you said about total pressure and the simulation is still not working. I get the same problem after a number of iterations. |
July 27, 2019, 03:26 |
#9 | |
Oskar
Rep Power: 10 |
Hello.
Why You are using those velocity and pressure inlets and outlets? I think Your simulation crashes when pressure wave reach inlet. Try to use different velocity and pressure inlet BC. https://www.openfoam.com/documentati...conditions.php Search for Inlet and Outlet BC. For example: Quote:
July 27, 2019, 09:29 |
Bruno Santos
Rep Power: 128 |
Quick suggestion: This blog post has a ton of information on how to set-up these kinds of simulations: http://matveichev.blogspot.com/2014/...ex-street.html
blockmesh, k-omega simualtions, openfoam 1.6 |
Strange density variations at cascade inlet. | michel89 | Fidelity CFD | 1 | June 9, 2015 00:46 |
Very strange phenomenon found at inlet | itsme_kit | FLUENT | 2 | March 10, 2014 16:48 |
bubbleFoam problems unstable and strange behaiviour | matt.mech.eng | OpenFOAM Running, Solving & CFD | 3 | September 5, 2012 07:41 |
Problems with Inlet species | San24 | Siemens | 1 | May 7, 2008 06:29 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
