k, epsilon, nut in buoyantBoussinesqPimpleFoam for laminar flows
Like Tree1Likes
  • 1 Post By simrego
Old   December 9, 2019, 14:18
Default k, epsilon, nut in buoyantBoussinesqPimpleFoam for laminar flows
Alex
Sedullo is on a distinguished road
I am quite new in OpenFOAM and in this forum, I need to simulate a problem of natural convection using buoyantBoussinesqPimpleFoam where the flow should very likely be always laminar.
-Will the values of k, epsilon, nut in the 0 folder be taken in consideration during the simulation or these values are not considered since the flow should be fully laminar?
-If these will be considered for the simulation, how can I determine the values I should insert in the 0 folder?
Thanks for the help.
Sedullo is offline   Reply With Quote
Old   December 10, 2019, 06:34
anonymous
simrego is on a distinguished road
Hi!
If you set your case to laminar, they wont. The turbulence model read them. If you don't have, they are redundant. OF always read only that field which is needed. Nothing more. You can put anything else into the folders, they won't affect the solver.
you can set laminar "turbulence model" in the constant/turbulencePorperties file.
yassine.bt likes this.
simrego is offline   Reply With Quote
Old   December 10, 2019, 17:06
Alex
It is a very clear explanation, thank you!
heat exchange, natural convection, turbulence and laminar
OpenFOAM-5 parallel problem on hpc littlebro OpenFOAM Running, Solving & CFD 15 September 5, 2019 10:20
(incompressible) interFoam - where is the density in the k, epsilon and continuity eq idefix OpenFOAM 0 December 22, 2015 14:40
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
Creating a new field from terms of the turbulence model HaZe OpenFOAM Programming & Development 15 November 24, 2014 13:51
