Natural convection boundary condition problem |
January 15, 2020, 09:58 |
Alex
Rep Power: 6 |
I need to study the heat transfer on a wall by natural convection, I am simulating a problem where the central part of the right side wall is heated, the left side wall is set to slip condition. I am using buoyantBoussinesqPimpleFoam
As you can see in the picture, a kind of vortex is created, instead, I expected that the flux should have gone upward entering from below, I attach here the bc I set, I hope you can find a way to fix the problem, because I have been struggling for some days on it and I cannot go ahead. Code:
FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { sideWallheated { type fixedFluxPressure; } rightsideWallsNotheated { type fixedFluxPressure; } leftsideWallsNotheated { type fixedFluxPressure; } inlet { type totalPressure; p0 uniform 0; } outlet { type totalPressure; p0 uniform 0; } Code:
FoamFile { version 2.0; format ascii; class volScalarField; object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 1 0 0 0]; internalField uniform 300; boundaryField { sideWallheated { type fixedValue; value uniform 340; } rightsideWallsNotheated { type zeroGradient; } leftsideWallsNotheated { type zeroGradient; } inlet { type inletOutlet; inletValue uniform 300; value uniform 300; } outlet { type inletOutlet; inletValue uniform 300; value uniform 300; } #includeEtc "caseDicts/setConstraintTypes" } Code:
FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { sideWallheated { type noSlip; } rightsideWallsNotheated { type noSlip; } leftsideWallsNotheated { type slip; } inlet { type outletInlet; outletValue uniform (0 0 0); value uniform (0 0 0); } outlet { type zeroGradient; } #includeEtc "caseDicts/setConstraintTypes" } |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 01:44 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
