rhoSimpleFoam with MRF (in rotation) outlet instability |
January 18, 2020, 07:09 |
Hi Foamers,
I am a relative newbie to this forum and would be interested in advice from others to help me fix my problem. I have a problem when running my mesh with rhoSimpleFoam using MRF (rotation). The mesh is a symmetrical fuselage with 4 blades placed around that fuselage. I have modelled the system as an annular duct (open on the inlet, outlet and circumference) and with the mesh quartered given the symmetry. The blade rotates at 1046rad/sec (200 metres/sec at the tip) about the centre-line of that duct fully within that duct, 0.6 metres from the inlet (0.3 metres from the outlet). The duct length is 0.9metres. When I run with the inlet and internal initial conditions at 0m/sec, the solution seems to be stablizing (at least to 33000 iterations) and the outlet distribution seems reasonable. However, if I set the same conditions to 30metres/sec the solution crashes at around 3500 iterations. Checkmesh shows some non-orthogonality, but the mesh passed (see attached). Examination of the mesh reveals that points on the outlet mesh have unexpected spikes in the distribution for the 30metres/sec case. This seems to start at around 3000 iterations (see U-3000.jpg). The spikes appear to have originated at or near the outlet (not the blade upstream). The spikes continue to expand with time until the crash. Checkmesh shows some non-orthogonality, but the mesh passed. The non-orthogonality appears to be no-where near the problem mesh (see Non-orthogonal.jpg) I have tried alternative U, P, etc outlet conditions, fvSchemes, fvSolutions etc but without finding a solution that matches the current stability (please check as I could easily have overseen something). Please can someone help identify where I am going wrong? My thoughts suggest I need to increase the length of the duct behind the blade to allow the flow to re-distribute better, but I am guessing. Thanks for your help. The attached files: conditions.docx - contains all files apart from the mesh to describe the test. jpg's - the U distribution at 3000 iterations, and the non-orthogonality at the outlet from inside the mesh. U-3000.jpg Non-orthogonal.jpg checkmesh_results.txt Results.txt Conditions.docx |
January 28, 2020, 13:49 |
Hi all.
Has anyone had any thoughts on this issue? Thanks. |
January 29, 2020, 00:37 |
Yogesh Bapat
Rep Power: 15 |
Non-orthogonality is high (87). You can try improving mesh. You can also try to use non-orthogonal correctors.
rhoSimpleFoam doubts on BC and fvSchemes (external aero) | giovanni.medici | OpenFOAM Running, Solving & CFD | 3 | October 27, 2021 05:06 |
Volume fraction at outlet not known | Bisht | FLUENT | 8 | September 5, 2017 02:38 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
VOF Outlet boundary condition in cfd - ace | JM | Main CFD Forum | 0 | December 15, 2006 08:07 |
Impinging Jet. Outlet Boundary Condition | Vincent | Main CFD Forum | 0 | December 16, 2003 10:49 |
