January 21, 2020, 11:52 |
Time step continuity Error
Rep Power: 6 |
Hello , I am trying to use the simpleFoam solver for a cylindrical flow for a rotating exhaust fan , but i seem to be getting these errors for every step
The time step continuity error seems to be diverging rather than converging Time = 5 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.091959499, No Iterations 5 smoothSolver: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 0, Final residual = 0, No Iterations 0 GAMG: Solving for p, Initial residual = 1, Final residual = 0.077236211, No Iterations 4 time step continuity errors : sum local = 0.0043637581, global = -2.3391276e-08, cumulative = -2.3391276e-08 smoothSolver: Solving for omega, Initial residual = 0.31633517, Final residual = 0.021362197, No Iterations 4 smoothSolver: Solving for k, Initial residual = 0.99999998, Final residual = 0.091347867, No Iterations 14 ExecutionTime = 293.99 s ClockTime = 301 s If possible can someone please help me with this , i am very new to OpenFoam , Thank you here is p file /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { AMI1 { type cyclicAMI; value uniform 0; } AMI2 { type cyclicAMI; value uniform 0; } exhaustfan { type fixedFluxPressure; value uniform 0; } inlet { type fixedFluxPressure; value uniform 0; } outlet { type fixedValue; value uniform 0; } rotating_zone { type fixedFluxPressure; value uniform 0; } } // ************************************************** *********************** // |
January 22, 2020, 04:00 |
Rep Power: 6 |
Ideas to try out:
transient calc, different BC and starting field, run checkMesh and see that the quality of mesh is not abhorrent, see that everything you put into the calc is physical, different turbulence modelling. edit: I don't have time to really look into it. But at the first glance.... Do you expect everything to be really zero with your BC? |
January 22, 2020, 04:38 |
Rep Power: 6 |
Mesh seems to be ok says a few volumes aren't connected to the faces, the values of 0 was just to try out , haven't actually calculated , have to try out others ,
I am not sure what kind of values to use for this , if anyone else can help with this one please do Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 1273985 internal points: 1182188 faces: 14617567 internal faces: 14433989 cells: 7252299 faces per cell: 4.005841 boundary patches: 6 point zones: 0 face zones: 2 cell zones: 2 Overall number of cells of each type: hexahedra: 0 prisms: 42360 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 7209939 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. *Number of regions: 2 The mesh has multiple regions which are not connected by any face. <<Writing region information to "0/cellToRegion" <<Writing region 0 with 256775 cells to cellSet region0 <<Writing region 1 with 6995524 cells to cellSet region1 Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology exhaustfan 8472 4238 ok (closed singly connected) rotating_zone 131376 65879 ok (non-closed singly connected) inlet 6287 3240 ok (non-closed singly connected) outlet 6287 3240 ok (non-closed singly connected) AMI1 15578 7791 ok (closed singly connected) AMI2 15578 7791 ok (closed singly connected) Checking geometry... Overall domain bounding box (-0.1502419 -0.1526393 -1.2) (0.1532621 0.1508648 0.25) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (6.802691e-16 -4.582934e-16 -6.291465e-17) OK. Max cell openness = 4.843088e-15 OK. Max aspect ratio = 174.3325 OK. Minimum face area = 2.046952e-08. Maximum face area = 2.851991e-05. Face area magnitudes OK. Min volume = 2.832708e-11. Max volume = 3.812381e-08. Total volume = 0.1045641. Cell volumes OK. Mesh non-orthogonality Max: 81.61225 average: 15.7007 *Number of severely non-orthogonal (> 70 degrees) faces: 8. Non-orthogonality check OK. <<Writing 8 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 2.811787 OK. Coupled point location match (average 0) OK. Mesh OK. End Last edited by Cfdjunior; January 22, 2020 at 21:30. |
January 31, 2020, 09:43 |
Rep Power: 6 |
Its still telling me that mesh surface/regions are not connected to faces , anyone any idea how to mend this , i havent actually used any meshing from Openfoam converted i.e totally ignored snappyhexmesh and blockmesh ,instead using Ansys
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
