mpirun has detected an attempt to run as root????
Old   January 24, 2020, 05:23
Default mpirun has detected an attempt to run as root????
niewiemnic
spalartallmaras is on a distinguished road
my account in Red Hat Enterprise Linux 7 is absolutely non-root user, but I can not start mpirun and see the error message.
mpirun has detected an attempt to run as root.
Running at root is *strongly* discouraged as any mistake (e.g., in
defining TMPDIR) or bug can result in catastrophic damage to the OS
file system, leaving your system in an unusable state.
You can override this protection by adding the --allow-run-as-root
option to your cmd line. However, we reiterate our strong advice
against doing so - please do so at your own risk.
Does someone have an idea?
spalartallmaras is offline   Reply With Quote
Old   November 17, 2020, 16:13
Marlon Lemos
mlemosd is on a distinguished road
Did you solve this problem?
mlemosd is offline   Reply With Quote
Old   December 22, 2020, 19:48
Vaishali Ravishankar
vaishaliravishankar is on a distinguished road
I would like to know if you have resolved this. Please let me know how
vaishaliravishankar is offline   Reply With Quote
Old   November 3, 2021, 04:10
Hosam Alrefaie
HosamAlrefaie is on a distinguished road
Did you solve the problem?
HosamAlrefaie is offline   Reply With Quote
Old   March 14, 2023, 09:52
Gerhard
Gerhard is on a distinguished road
You can try adding this to your .bashrc file:
export OMPI_ALLOW_RUN_AS_ROOT=1
export OMPI_ALLOW_RUN_AS_ROOT_CONFIRM=1
Gerhard is offline   Reply With Quote
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 07:54
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 16:08
missing vtf3.h BPatch.h papi.h linch OpenFOAM Installation 41 July 24, 2012 14:45
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
MPI PROBLEMS gtg627e OpenFOAM Running, Solving & CFD 20 October 5, 2007 04:02
