Specify velocity with pressureInletOutletVelocity |
February 26, 2020, 07:54 |
Herman Bordal
Rep Power: 6 |
I am simulating oscillating flow in the domain, I am doing that by applying a pressure difference at the inlet and outlet to achieve the desired velocity. Unfortunately I struggle with the occurrence of singularities in the domain causing the solution to explode, I was advised to define the inlet velocity at one side in addition to the pressure difference. Is this possible with type pressureInletOutletVelocity or pressureNormalInletOutletVelocity? I've tried changing the line value uniform (0 0 0); to include table, but haven't figured out the right syntax. In advance thanks |
serial udf to parallel udf | radioss | Fluent UDF and Scheme Programming | 10 | January 19, 2019 08:56 |
wrong velocity contour of rotating propeller - Fluent | calv | FLUENT | 1 | September 6, 2018 11:48 |
Velocity in Porous medium : HELP! HELP! HELP! | Kali Sanjay | Phoenics | 0 | November 6, 2006 06:10 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
