In least square gradient method, which step solve the least square problem. |
I Cann't find the step to solve the least square problem Ax=b for the gradient. Could you give me some suggestions
template<class Type> Foam::tmp < Foam::GeometricField < typename Foam::outerProduct<Foam::vector, Type>::type, Foam::fvPatchField, Foam::volMesh > > Foam::fv::leastSquaresGrad<Type>::calcGrad ( const GeometricField<Type, fvPatchField, volMesh>& vsf, const word& name ) const { typedef typename outerProduct<vector, Type>::type GradType; const fvMesh& mesh = vsf.mesh(); tmp<GeometricField<GradType, fvPatchField, volMesh>> tlsGrad ( new GeometricField<GradType, fvPatchField, volMesh> ( IOobject ( name, vsf.instance(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), mesh, dimensioned<GradType>(vsf.dimensions()/dimLength, Zero), extrapolatedCalculatedFvPatchField<GradType>::typeName ) ); GeometricField<GradType, fvPatchField, volMesh>& lsGrad = tlsGrad.ref(); // Get reference to least square vectors const leastSquaresVectors& lsv = leastSquaresVectors::New(mesh); const surfaceVectorField& ownLs = lsv.pVectors(); const surfaceVectorField& neiLs = lsv.nVectors(); const labelUList& own = mesh.owner(); const labelUList& nei = mesh.neighbour(); forAll(own, facei) { label ownFacei = own[facei]; label neiFacei = nei[facei]; Type deltaVsf = vsf[neiFacei] - vsf[ownFacei]; lsGrad[ownFacei] += ownLs[facei]*deltaVsf; lsGrad[neiFacei] -= neiLs[facei]*deltaVsf; } // Boundary faces forAll(vsf.boundaryField(), patchi) { const fvsPatchVectorField& patchOwnLs = ownLs.boundaryField()[patchi]; const labelUList& faceCells = vsf.boundaryField()[patchi].patch().faceCells(); if (vsf.boundaryField()[patchi].coupled()) { const Field<Type> neiVsf ( vsf.boundaryField()[patchi].patchNeighbourField() ); forAll(neiVsf, patchFacei) { lsGrad[faceCells[patchFacei]] += patchOwnLs[patchFacei] *(neiVsf[patchFacei] - vsf[faceCells[patchFacei]]); } } else { const fvPatchField<Type>& patchVsf = vsf.boundaryField()[patchi]; forAll(patchVsf, patchFacei) { lsGrad[faceCells[patchFacei]] += patchOwnLs[patchFacei] *(patchVsf[patchFacei] - vsf[faceCells[patchFacei]]); } } } lsGrad.correctBoundaryConditions(); gaussGrad<Type>::correctBoundaryConditions(vsf, lsGrad); return tlsGrad; } |
Rep Power: 15 ![]() |
Is it not in leastSquaresVectors? A quick look at that code reveals that it contains an inversion step. Note I've not done a deep dive into the code, but it looks like a good place to start.
Caelan |
Thanks a lot, i have find it. It was calculated in the constructor().
Santiago Marquez Damian
Rep Power: 24 ![]() |
Hi, its is done in two steps, the geometrical part (this not change if mesh is static) is precomputed in leastSquaresVectors, then the gradient is finally computed in calcGrad method.
Regards!
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
Display Modes | |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
p_rgh initial residual no change with different settings | manuc | OpenFOAM Running, Solving & CFD | 3 | June 26, 2018 15:53 |
Stuck in a Rut- interDyMFoam! | xoitx | OpenFOAM Running, Solving & CFD | 14 | March 25, 2016 07:09 |
extremely simple problem... can you solve it properly? | Mikhail | Main CFD Forum | 40 | September 9, 1999 09:11 |
use of MAC method to solve sloshing problem. | S.R.SAHI | Main CFD Forum | 1 | April 15, 1999 22:28 |
