Flux calculation in electrostaticFoam
Like Tree1Likes
  • 1 Post By syavash
Old   April 15, 2020, 18:06
Default Flux calculation in electrostaticFoam
Syavash Asgari
syavash is on a distinguished road
Dear Foamers,
I see that in electrostaticFoam solver, flux has been calculated as follows:
rhoFlux = -k*mesh.magSf()*fvc::snGrad(phi);
where k in some scalar and phi is the electric potential:
        solve
            fvm::laplacian(phi) + rho/epsilon0
Accordingly, the electric field vector can be obtained in the following way:
volVectorField E = -fvc::grad(phi)
Now, my question: is it correct to calculate the flux using the following relation:
rhoFlux = fvc::interpolate(-k*E) & mesh.Sf();
The line above is consistent with the flux calculation in pimpleFoam for instance, but I get divergence when I apply it in my code instead of the first expression. Is there a significant difference between these two methods?
I appreciate any help
Kind regards,
syavash
tonnykz likes this.
syavash is offline   Reply With Quote
Old   June 28, 2020, 20:50
Rango is on a distinguished road
The resaon for solver crash using your approach is that there is a small sign typo in your flux equation. The correct form of the equation would be:
rhoFlux = fvc::interpolate(k*E) & mesh.Sf();
Even though these two approaches may seem the same, they may lead to different results on numerical level. In your proposed approach, you introduce an extra source of error due to (unnecessary) interpolation of a field (here E), while in the original approach the gradient is computed directly on mesh faces using "surface-normal gradient" operator, "snGrad".
In this case you may get away with the introduced gradient error, but in general it can result in non-physical "checkerboard" effects.
Cheers
Rango is offline   Reply With Quote
electrostaticfoam, rhoflux
Calculation of spectral transfer flux T(k) gharek Main CFD Forum 3 August 1, 2017 12:51
calculation of wall heat flux in CHT richard CFX 1 July 23, 2009 09:00
Flux calculation across a boundary hirokata Siemens 3 July 4, 2008 00:25
Warning 097- AB Siemens 6 November 15, 2004 04:41
Turbulence Model and Accuracy of convective flux calculation Lokesh Agrawal Main CFD Forum 1 November 14, 1998 23:24
