bad heat transfer results with low y+
Old   April 29, 2020, 11:56
Default bad heat transfer results with low y+
james freak
me45 is on a distinguished road
Hi
I am interested in obtaining wall heat flux of a rocket engine (so 2D axisymetric).
  • I am using k omega SST turbulence model
  • solver is rhoPimpleFoam (modified to account for viscous heating).
  • My divergence schemes are :
         default         none;
        div(phi,U)      Gauss upwind;
        div(phid,p)     Gauss limitedLinear 1;
        div(phi,K)      Gauss limitedLinear 1;
        div(phiv,p)     Gauss limitedLinear 1;
        div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
        div(phi,h)      Gauss limitedLinear 1;
        div(phi,k)      bounded Gauss upwind;
        div(phi,omega)  bounded Gauss upwind;        div((nuEff*dev2(T(grad(U))))) Gauss linear;
    // For viscosity heating
        div(U)          Gauss linear;
        div(((((rho*nut)+thermo:mu)*(grad(U)+grad(U).T()))&U)) Gauss linear;
        div((((0.666667*((rho*nut)+thermo:mu))*div(U))*U))  Gauss linear;
  • I have seen on several post that for heat transfer problems, a low Re formulation is better, so I initiallly used that.
  • My mesh is ok except for high aspect ratio (but this is inevitable when resolving the whole boundary layer and should not be a problem according to many CFD users). My cells gets a growth factor around 1.15 in the BL and have a constant size far from it.
  • Wall conditions are:
    k:  kLowReWallFunction;
    omega: omegaWallFunction;
    nut:    nutLowReWallFunction;
            Cmu             0.09;
            kappa           0.41;
            E               9.8;
            value           uniform 0;
    alphat: compressible::alphatWallFunction;
               Prt             0.85;
               value           uniform 0;
I have run a first simulation, the maximum y+ value is 7 (the first 2 pictures represents y+ and wall heat flux qw). Results does not seem bad: same shape of qw but overestimated by 15% of results obatin with an over software.
Then I refined the mesh to get my maximum y+ closer to 1. Now trouble starts: the time step loss 3 order of magnitude (to respect the maximum Co=0.5) so computational time becomes really high. Besides my residuals falls to 1e-7 (instead of 1e-5) and results get mad: y+ and qw distribution becomes really bad. I have upload the residuals, y+ and qw for this case.
There is clearly something going wrong as I get a courant Number of 0.5 in a small part of the nozzle close to the wall whereas my mean Co is two order of magnitude lower (the part where Co=0.5 change when I change refine more or less the mesh).
My mesh is ok except for high aspect ratio (but this isinevitable when resolving the whole boundary layer and should not be a problem according to many CFD users). My cells gets a growth factor around 1.15 in the BL and have a constant size far from it.
I also have run a High Re simulation (changing the wall boundary condition),
k:  kqRWallFunction;
nut:    nutUSpaldingWallFunction;
alphat:  compressible::alphatJayatillekeWallFunction;
the first simulation is done with y+ totally in buffer region but gives almost same results than the Low Re simulation (the one that gives acceptable results). As y+ was in buffer region region I increased it to be >30 as CFD guys recommend to avoid buffer layer because results would be bad, but then my results are bad, esoecially in the high velocity region of my mesh.
I have done many simulation to investigate that but can't answer these question:
  1. Why when refining to get a lower y+ values my simulation show this bad behaviour? What can I investigate?
  2. CFD guys recommend to avoid buffer layer because results gets bad, but this was not the case for my example. Does k omega SST enables to get good results even if we are in buffer region as it use blended function? Can I trust these results ?
  3. I get bad results when y+>30, is it because of that that usually people advise not to use High Re (wall function) for heat transfer study or can it comes from something else ?
  4. I also have in some simuation a high frequency variation of omega residuals (between 1e-5 and 1e-6), I can't find what cause that. Can it have an impact on results?
  5. about the alphat wall condition, we have the choice between compressible::alphatJayatillekeWallFunction; and compressible::alphatWallFunction. According to alphatWallFunction vs alphatJayatillekeWallFunction , the Jayatilleke is better for high and low Re so what is the alphatWallFunction good for ?
Ask me If you need more information.
I would really appreciate if someone can respond to at least one of my question.
me45 is offline   Reply With Quote
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
Radiation interface hinca CFX 15 January 26, 2014 17:11
Question about heat transfer simulation Anna Tian Main CFD Forum 0 January 25, 2013 18:53
Heat Transfer mechanisms tafaugl CFX 1 November 7, 2012 18:46
transient heat transfer - radiation model - implausible results thomasduerr OpenFOAM Running, Solving & CFD 0 July 13, 2009 10:03
