k-omega-SST: what happens when nut is set to 'calculated' at the wall for y+<1
Old   May 11, 2020, 18:09
Default k-omega-SST: what happens when nut is set to 'calculated' at the wall for y+<1
sapujapu is on a distinguished road
Hello everyone,
I'm trying to model a heat transfer problem and therefore want to pay special attention to my boundary layer treatment.
The plan is to resolve the boundary layer with prisms so that y+<1 and therefore not rely on wall functions. I want to use the k-omega SST turbulence model as the literature shows that it performs well in my problem and because it's capable of fully resolving the boundary layer.
My original plan was to set the following BC at the wall:
k: kLowReWallFunction
omega: omegaWallFunction
nut: nutLowReWallFunctions
However, I am quite unsure about the BC for nut. From the OF BC Guide, I know that nutLowReWallFunction simply sets nut to zero. Intuitively, this makes sense to me, as there are no turbulent fluctuations at the wall and therefore zero turbulent viscosity. Please correct me though if I'm wrong here.
A colleague of mine told me that he usually uses 'calculated' for the nut wall BC. I don't really understand the point behind this though: if this BC is used, how exactly is nut calculated and how is this result going to look like? Is it simply calculated as \nu_t = a_1 \frac{k}{max(a_1 \omega , b_1 , F_{23}S)} ? (Equation for nut fromk-omega-SST model)
If yes, it looks like it does go to zero because the turbulent kinetic energy k should be zero at the wall (at least according to my intuition).
I hope my question is somewhat clear, it would be really cool if someone could help me out there. Thanks!
sapujapu is offline   Reply With Quote
Old   June 3, 2020, 07:05
geth03 is on a distinguished road
i also use the k-omega-sst turbulence model.
for walls, i use nutkWallFunction.
nut takes really small values at walls, like you assumed, but in my case
never is 0. (e-5 to e-10)
your equation for nut is correct.
here is the link to the model:
https://www.openfoam.com/documentati...omega-sst.html
geth03 is offline   Reply With Quote
Old   June 4, 2020, 05:44
Ruiyan Chen
cryabroad is on a distinguished road
"calculated" means to calculate the quantity based on the way it should be calculated, instead of doing something to it. So you are right, if you use "calculated" on nut, it means you calculate nut based on how it should be calculated, i.e., from the model itself.
I'm not so sure about having such a fine mesh for RANS though. To me, the whole idea of using RANS is to reduce computational resources. So, the mesh doesn't have to be very fine, and wall models are used to give reasonable results for a coarse mesh (especially towards the wall). Maybe you are having troubles getting reasonable results when using wall models? If that's the case do you mind share the problems? I'm kind of interested.
cryabroad is offline   Reply With Quote
Old   June 13, 2020, 09:41
Claudio Boezio
Ship Designer is on a distinguished road
In the formula for calculating nut, what are the symbols F_23 and S? Thanks.
Ship Designer is offline   Reply With Quote
does Hyperthreading affect the application of UDF? SJSW Fluent UDF and Scheme Programming 11 October 10, 2018 23:28
Implementation of new omega and nut wall functions zordiack OpenFOAM Programming & Development 4 December 6, 2016 16:17
Boundary Conditions for k omega SST dancfd OpenFOAM Pre-Processing 0 June 10, 2011 00:25
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 05:27
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
