May 22, 2020, 10:20 |
Residuals suddenly "explode" (aerodynamics)
Andrea Stedile
Rep Power: 6 |
I'm trying to simulate an Ahmed body.
Overall, the simulation setup is identical to the of the Motorbike tutorial (k-w SST). I only changed the following stuff: - Turbulence variables (taken from this Simscale validation project): flowVelocity: 63.7 m/s k: 21.9 w: 29215 - I enlarged the wind tunnel - I changed the ollowing conditions: fvSchemes: Code:
ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; grad(U) cellLimited Gauss linear 1; } divSchemes { default none; div(phi,U) Gauss linearUpwindV Gauss linear; div(phi,k) Gauss linear; div(phi,omega) Gauss linear; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } wallDist { method meshWave; } Code:
solvers { p { solver GAMG; smoother GaussSeidel; tolerance 1e-7; relTol 0.001; } Phi { $p; } U { solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0.01; nSweeps 1; } k { solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0.01; nSweeps 1; } omega { solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0.01; nSweeps 1; } } SIMPLE { nNonOrthogonalCorrectors 0; } potentialFlow { nNonOrthogonalCorrectors 10; } relaxationFactors { fields { p 0.3; } equations { U 0.7; k 0.7; omega 0.7; } } cache { grad(U); } These are the cutting planes for the Pressure and Velocity taken at about 2000 time steps (spoiler: nothing good. A few iterations later the simulation crashed). Here there are the log.simpleFoam, log.snappyHexMesh files. Mesh seems to be fine: Code:
Overall number of cells of each type: hexahedra: 1756966 prisms: 3473 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 30027 Breakdown of polyhedra by number of faces: faces number of cells 4 20 5 83 6 2629 7 1044 8 206 9 24319 10 20 12 1570 15 116 18 20 [...] Checking geometry... Overall domain bounding box (-2 0 -4.33681e-19) (9 3 5) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (1.62399e-15 -3.55151e-15 -2.00762e-17) OK. Max cell openness = 3.71841e-16 OK. Max aspect ratio = 18.9396 OK. Minimum face area = 9.28447e-07. Maximum face area = 0.00396961. Face area magnitudes OK. Min volume = 1.68502e-09. Max volume = 0.000248606. Total volume = 164.945. Cell volumes OK. Mesh non-orthogonality Max: 64.0492 average: 4.45301 Non-orthogonality check OK. Face pyramids OK. Max skewness = 3.38809 OK. Coupled point location match (average 0) OK. Mesh OK. |
residuals stay converged until 2000 iterations, then suddenly diverge | frossi | CFX | 1 | June 6, 2017 18:36 |
plot residuals | pigna | OpenFOAM Running, Solving & CFD | 2 | December 19, 2014 02:32 |
motorBike Residuals for SST k-omega... and mine | JR22 | OpenFOAM Running, Solving & CFD | 6 | August 1, 2013 09:08 |
judging convergence through residuals | MachZero | Main CFD Forum | 7 | December 25, 2012 12:18 |
Convergence - scaled vs unscaled residuals | HS | FLUENT | 1 | November 7, 2005 05:45 |
