June 22, 2020, 09:18 |
Rotating mesh (AMI) with ANSYS Meshing
Jacques Durand
Rep Power: 5 |
I am working on a Vertical Axis Wind Turbine (VAWT). I want to do a dynamic simulation with pimpleDyMFoam. My problem is to define the interface between the static part and the rotating part. The rotating part is a cylinder around the wind turbine. I defined the faces of the cylinder as a wall with the tool "Named selections", called cylinder. I don't know how to define the rotating zone after I converted the mesh in OpenFOAM. I have the AMI1 from the cylinder when I run createPatch but I can't create AMI2 (this boundary condition is empty). I think I need to add this but I don't know where to write it and if it's correct : Code:
AMI { faceType boundary; cellZone rotatingZone; faceZone rotatingZone; cellZoneInside inside; } Thank you for your answers, Jacques |
June 23, 2020, 02:04 |
Yogesh Bapat
Rep Power: 15 |
You can read the mesh in Fluent. Then it will create wall and wall shadow. You can write this case. Then use this case to generate openfoam mesh. Then polyMesh will contain both wall and wall-shadow as "wall" boundaries in boundary file. Now you can change these to AMI.
-Regards, -Yogesh |
June 23, 2020, 03:28 |
Jacques Durand
Rep Power: 5 |
I couldn't do that because I don't have Fluent (I just have Design Modeler and ANSYS Meshing). Is there another solution ?
Best regards, Jacques |
August 4, 2023, 11:44 |
Sebastián Agudelo
Rep Power: 5 |
Hi Jacques, were you able to solve this problem?
ami, ansys, pimpledymfoam, rotating mesh |
[ANSYS Meshing] Is it possible to generate mesh in different cell zones in Ansys meshing? | aja1345 | ANSYS Meshing & Geometry | 0 | October 3, 2018 14:22 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 11:45 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
