June 2, 2020, 22:52 |
oscillating 2D drop mesh convergence
Josh McCraney
Rep Power: 8 |
Hi FOAMers!
I am running interFoam version 6. I am looking at an inviscid 2D drop of water in air with zero g. I give the drop a slight disturbance, which causes the drop to oscillate back to equilibrium. When I perform a mesh-convergence study, the results for dx = 40 and 100 are much closer to the analytic prediction than dx = 200: why? I have a limit on the max Courant number, so I don't think it's a time step issue. What do you think? For your consideration, my controlDict looks like this Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application interFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 0.02;//1000; deltaT 0.000000001; // INITIAL TIME STEP writeControl adjustableRunTime; writeInterval 0.0002; purgeWrite 0; writeFormat binary; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep yes; maxCo 0.2; maxAlphaCo 0.2; maxDeltaT 1;//0.0000025; functions { waterVolume { type volFieldValue; libs ("libfieldFunctionObjects.so"); log true; writeControl writeTime; writeFields true; regionType all; operation volIntegrate; fields ( alpha.water ); } } // ************************************************************************* // |
July 11, 2020, 05:25 |
eco
Rep Power: 9 |
I have two suggestions, convergence-wise. I assume this is laminar, thus U-p coupling only with the calculation of the liquid fraction via the MULES solver.
1. As for MULES, you might want to check independence of its subcycles i.e.nAlphaSubCycles and nAlphaCorr. 2. Also more general. It seems like you chose a convective CFL~0. 2 driven solution. I assume you might use the PISO mode at this time step. However, I would recommend lowering the initial linear solver residuals more restrict each time step, thus using the PIMPLE framework to guarantee independence of residuum and a successive lowering of the inital residuums of from 1e-5 down to 1e-8 or so. Last edited by magnushaese; July 12, 2020 at 19:00. |
Poor convergence: just mesh or numerics? | piotr.mecht | OpenFOAM | 10 | May 12, 2020 11:05 |
Increase in pressure drop when refine the mesh | Thromkar | FLUENT | 4 | December 5, 2018 14:13 |
[Other] Generating Mesh for a drop in another fluid | Prosper | OpenFOAM Meshing & Mesh Conversion | 10 | October 19, 2017 02:27 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
