Implementing supersonic free stream boundary condtion
Like Tree1Likes
  • 1 Post By ano
Old   June 8, 2020, 19:21
Default Implementing supersonic free stream boundary condtion
Saikumar Reddy Y
Saikumar Bunni is on a distinguished road
Am trying a transonic simulation of a supersonic intake, using rhoPimpleFoam and as shown in the figure, top wall (small portion) of the boundaries has to be atmosphere.
For this I tried imposing totalTemperature in 0/T, totalPressure in 0/p and supersonicFreeStream boundary for velocity in 0/U.
But it doesn't work.
So I have used slip boundary condition along with zero gradients of pressure and Temp.
But I eventually want something similar to pressure far-field BC on Fluent. Is there any variant of it for OF?
Find the geometry pic attached. Note that the lines in red represent the shock.
0/U:
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 7
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (3.53 0 0);
boundaryField
inlet
type fixedValue;
value uniform (3.53 0 0);
outlet
type zeroGradient;
wall
type noSlip;
inletOutlet
type slip;
frontAndBack
type empty;
0/p:
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 1;
boundaryField
inlet
type fixedValue;
value uniform 1;
outlet
type waveTransmissive;
field p;
psi thermo:psi;
gamma 1.4;
fieldInf 1;
lInf 3;
value uniform 1;
inletOutlet
type zeroGradient;
wall
type zeroGradient;
frontAndBack
type empty;
0/T:
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
object T;
dimensions [0 0 0 1 0 0 0];
boundaryField
inlet
type fixedValue;
value uniform 1;
outlet
type zeroGradient;
wall
type zeroGradient;
inletOutlet
type zeroGradient;
frontAndBack
type empty;
Saikumar Bunni is offline   Reply With Quote
Old   June 9, 2020, 04:07
ano
ano
ano is on a distinguished road
Hi Saikumar,
the equivalent should be the waveTranmissive boundary condition.
I could imagine that rhoCentralFoam or dbnsFoam (from foam-extend) are more suitable for your problem (especially if you are interested in an accurate resolution of the shocks).
Saikumar Bunni likes this.
ano is offline   Reply With Quote
Old   June 15, 2020, 20:18
Default Cannot capture Normal shock
Saikumar Reddy Y
Originally Posted by ano View Post
Hi Saikumar,
Hi I tried the dbnsFoam solver for my supersonic intake case. But I could not capture the Normal shock in my system (figure 2). My free stream Ma was 2.4, and is 1.85, 1.3565 after 1st and 2nd oblique shocks. I expect a Normal shock at the location of Area expansion. Analytical results show my temperature at the end of the duct is roughly 1.93K (scaled) and pressure is 8.8Pa. My simulation, even after 35 seconds couldnt get the Normal shock in it. As shown in the figure 1 and 3, it shows the values I specified at the outlet at the last cells only. My boundary conditions are in simple as follows.
_______________p_______________________T ______________________ U
inlet_______Fixed-value 1Pa_______________ Fixed-value 1Pa_____________supersonic Free-stream 2.4 Ma
outlet______Wave-trans – fieldInf – 8.8Pa_____Fixed-value 1.93K____________zero Grad
inlet Outlet__Wave-trans – fieldInf – 1Pa______inlet Outlet – value 1K_________supersonic Free-stream 2.4m/s
wall________zero Grad___________________zero Grad___________________fixed value – 0 0 0
frontAndBack empty
File Type: jpg Screenshot from 2020-06-16 01-12-16.jpg (49.4 KB, 42 views)
File Type: jpg Screenshot from 2020-06-14 00-36-54.jpg (29.3 KB, 18 views)
File Type: png Screenshot from 2020-06-16 01-13-15.png (128.1 KB, 15 views)
Old   June 16, 2020, 03:31
ano
ano
Perhaps you could try to use a finer grid (to see whether this gives you the normal shock), decrease fieldInf at the outlet to 3.6 Pa and increase linf (to get rid of the jump at the outlet).
Which schemes did you take?
Old   June 21, 2020, 13:27
Default Supersonic intake simulations with waveTransmissive pressure outlet
Saikumar Reddy Y
I have been struggling with altering b/n schemes and boundary conditions. I read in the literature that for a transonic case with a supersonic inlet, an isolator and a CD nozzle can be used at the downstream end to reduce pressure wave reflections. I have done the same, and the CD nozzle now brings down the pressure at the outlet to 1Pa. But still my case gets crashed. Please find the pdf file (link below) for the geometry and boundary conditions, and also the case files are attached. I have used both rhoCentralFoam and dbnsFoam, but none worked. Please check the readme file to the run the cases.
For the schemes, I haven't changed much from the default one provided on dbnsFoam,
using rusanov flux splitting with BerthJespersen limiter. Tried HLLC which offers greater stability, it didn't work either.
https://drive.google.com/drive/folde...HY?usp=sharing
Old   June 29, 2020, 08:01
ano
ano
Can you try the following Schemes in the dbns case?
flux hllc;
limiter firstOrder;
Making dbnsFoam run comes down to refining the mesh a lot and keeping the Courant number low (<0.3). I could imagine that you need 0.5-1 million cells.
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
How to get free stream temperature in boundary condition saharesobh FLUENT 0 October 9, 2012 17:12
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
