twoPhaseEulerFoam particle diameter
Old   June 13, 2020, 09:27
Default twoPhaseEulerFoam particle diameter
Jagan Mohan
jagan1mohan is on a distinguished road
Hello Team, I'm looking to compare twoPhaseEulerFoam (2PEF) and CFDEM setup via simulating minimum fluidization velocity. The particle diameter is 1.2 mm.
In phaseProperties, I'm declaring phases as (particles air). Here, I use diameterModel as constant and set d as 0.0012; for particle.
1. How do we estimate the alphaMax value?
Also, for air too we use diameterModel as constant and set d as 1.
2. Why are we setting air diameter to 1?
Thank you,
Jagan Mohan.
jagan1mohan is offline   Reply With Quote
diametermodel, twophaseulerfoam
Particle diameter calculation hebe2u CFX 4 February 21, 2019 04:43
twoPhaseEulerFoam - particle diameter distribution Elm OpenFOAM Pre-Processing 2 December 4, 2018 04:23
particles leave domain Steffen595 CFX 9 March 7, 2016 16:19
TwoPhaseEulerFoam high particle diameter problem OF2.1.1 mwaqas OpenFOAM Running, Solving & CFD 0 May 24, 2015 08:45
injection problem Mark New FLUENT 0 August 4, 2013 01:30
