Parallel job killed - snappyHexMesh log deleted
Old   June 18, 2020, 09:35
Default Parallel job killed - snappyHexMesh log deleted
Vania
VLima is on a distinguished road
I had a simulation running on a shared cluster, results were being written/output and when it reached a certain time step, the process was suddenly killed in the instruction concerning the snappyHexMesh:
snappyHexMesh -overwrite > snappyHexMesh.log
as it strangely stepped back in the simulation.
This was the complete error message I got:
runCasePiston_alltime: line 13: 34820 Killed                  snappyHexMesh -ov$
[demec03][[11190,1],31][btl_openib_proc.c:157:mca_btl_openib_proc_create] [btl_$
slurmstepd: error: Detected 1 oom-kill event(s) in step 149267.batch cgroup. So$
and then I noticed that (I suppose that as a consequence of this error) the snappyHexMesh.log was deleted from the simulation folder (log file that was previously there).
I was wondering of anyone has ever experienced such a thing and maybe found some reasons for this to happen.
Openmpi is used ( mpi/openmpi-x86_64 ).
Any ideas or feedback are most welcome.
Many thanks in advance!
VLima is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 7 June 14, 2022 01:37
Partitioning problems in the parallel job Neo FLUENT 5 January 26, 2021 10:10
OpenFoam parallel running log issue clktp OpenFOAM Running, Solving & CFD 2 January 19, 2016 09:12
parallel fluent runs being killed at partitioing Ben Aga FLUENT 3 June 8, 2012 10:40
motorBike running snappyHexMesh in parallel? klausb OpenFOAM Running, Solving & CFD 0 December 5, 2011 18:58
