June 19, 2020, 09:41 |
Very Low deltaT after just few iterations
fpp prr
Rep Power: 5 |
Hi everybody,
I'm running a simulation with pimpleDyMFoam and turbulence model kEpsilon, after just a few iterations deltaT drops to very low values (order of e-20) and a very high y+ value (order of e18). I cannot understand if the problem are the mesh and BC or the set up of schemes, solution and controlDict. Here attached fvSchemes, fvSolution and controlDict. Thanks in advance. |
June 23, 2020, 00:23 |
raphael
Rep Power: 10 |
In your controlDict you have adjustTimeStep yes;
And maxCo 1; So deltaT will drop until it reaches the constraint maxCo < 1 At the moment you could change adjustTimeStep to no. We don't have enough info to help you more. You could run some iteration and have a check on paraview to see where the problem is located. You are looking for high-velocity cells. |
June 23, 2020, 12:39 |
fpp prr
Rep Power: 5 |
Problem solved, the main issue was inconsistency between mesh and turbulence model adopted, thank you anyway
December 28, 2023, 04:09 |
#4 | |
Chandra Napitupulu
Rep Power: 2 |
How do you know that the problem was inconsistency between mesh and turbulence? I have same the problem when I use pimpleFoam as solver for simulation of underwater vessel |
Problem with chtMultiregionFoam radiation boundary condition | baran_foam | OpenFOAM Running, Solving & CFD | 10 | December 17, 2019 17:36 |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 22:13 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
