How to represent a fan on a simulation?
Like Tree11Likes
  • 1 Post By igor.leo93
  • 8 Post By igor.leo93
  • 1 Post By parthigcar
Old   February 5, 2018, 09:36
Default How to represent a fan on a simulation?
igor.leo93's Avatar
Igor Leonardo
igor.leo93 is on a distinguished road
Hello everyone,
I have some questions concerning representation of a fan on a simulation. Basically:
1- How do I apply the fan curve on a simulation (Boundary conditions)?
I would like to see the flow rate change to a value equivalent to the operating point regarding the system resistance curve and the fan curve.
2- Is it possible to apply a rotating flow at inlet?
I know the RPM curve as a function of either velocity or pressure, I would like to add a tangential velocity vector on the inlet for example.
See my case bellow for more information please:
Basically, I took a random fan and it’s curves from the Internet, then, I modeled a 3D geometry of a tube with an obstruction. In a manner that I could drawn the system resistance curve and the fan curve and see the operating point. So I simulated it with simpleFOAM and the results matched my calculations. Now I would like to add the fan effects on the simulation, and see the flow rate drop as a function of the system resistance until the pressure provided by the fan is equal to the total head loss.
I will show here some information, but the full case is attached with an excel containing all the information.
denbjornen likes this.
igor.leo93 is offline   Reply With Quote
Old   February 5, 2018, 09:45
Default Continued
igor.leo93's Avatar
Igor Leonardo
For Details, see attached images 1 2 3 and 4.
So, considering this fan, the operating point would be at 0.76 m³/min with a inserted pressure difference of 109 Pa, while the system resistance is 105.25 Pa, so I applied this flow rate on the inlet and the calculations were confirmed, some plots: See attached image 5
Now all I want to do is change the boundary conditions in a way that this fan is represented, and operating point would be obtained via simulation, and insert the “rotation” due to the fan would be nice too if possible.
I hope someone more experienced with fan analysis can give me some tips, I found some information on the forum about how to do this but couldn’t understand it very well, I am only used to do very simple simulations with simpleFoam.
Any help is appreciated.
Thanks.
Igor
raj kumar saini likes this.
Old   February 5, 2018, 13:36
Default Fan curve
igor.leo93's Avatar
Igor Leonardo
Ok just an update, i've managed to find out how to insert the fan curve. It's pretty simple actually.
I will post here the changes in case anyone else needs.
The changes are basically to the p and U files.
For U:
boundaryField
    inlet
        type            pressureInletOutletVelocity;
        value           uniform (0 0 0);
    outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
    walls
        type            noSlip;
and for p:
boundaryField
    inlet
       type            fanPressure;
       file        "./constant/fanCurve";
       outOfBounds     clamp;
       direction       in;              // in | out
       p0              uniform 0;
       value           uniform 0;
    outlet
        type            fixedValue;
        value           uniform 0;
    walls
        type            zeroGradient;
Notice how on the inlet it is now associated with a file named "fanCurve". Which means that now we need to create a file inside our constant folder named "fanCurve". The file must look like something like this:
|  \\    /   O peration     | Version:  5.x                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       IOobject;
    location    "constant";
    object      fanCurve;
8
(0.00000    124.48)
(0.01267    90.46)
(0.01533    74.69)
(0.01950    63.90)
(0.02300    59.34)
(0.02983    56.43)
(0.03533    47.30)
(0.04550    0.00)
It is important to notice:
1- The first line contain the amounts of points to be considered.
2- The first column must be in the units of m³/s and the second one either kinematic pressure or Pa (Depends on the solver you are using, in my case it's kinematic, because i'm using simpleFoam).
This is it, the solution converged to the same results as i had calculated, as can be seen on the attached pictures.
Old   October 9, 2020, 08:56
parth
parthigcar is on a distinguished road
Hi Igor, thank you for the explaination. I had a doubt, how to incorporate the fan RPM and diameter for similar problem?
parthigcar is offline   Reply With Quote
Old   June 21, 2022, 19:55
Default fanPressure in openFOAM 8
Jeferson Souza
jasouza1974 is on a distinguished road
I'm trying to use the fanPressure boundary condition with openFOAM 8 (of8).
I solved this problem in of7 without any problem, however when I try to solve the same problem in of8 (or of9) it simply does not work. Both pressure and velocity are set to zero at the inlet boundary.
I corrected the boundary condition for the new syntax. I got no errors, however I got no solution either.
Does anyone knows what is different in of8?
Thanks.
jasouza1974 is offline   Reply With Quote
curve, fan, openfoam, rotation, simplefoam
How to build current blower fan model in Flotherm eric0722 FloEFD, FloWorks & FloTHERM 3 January 2, 2021 02:36
Fan simulation with inlet and outlet duct chaudhry_hashim STAR-CCM+ 0 June 27, 2014 08:59
fan driven flow, Fan BC validation (getting lost) soonic OpenFOAM Running, Solving & CFD 0 July 7, 2013 19:16
Question) fan simulation & B.C Serazio FLUENT 0 February 7, 2011 13:27
FloEFD Heat Sink Simulation feature, but with no fan? j.gerber FloEFD, FloWorks & FloTHERM 0 September 7, 2009 08:37
