alexander thierfelder
Rep Power: 6 ![]() |
** Prandtl : )
I worked me throug the source code of kOmegaSST and notices that in the model Coefficients no turbulent Prantl number is set. So I went to the calulation of alphat in /src/TurbulenceModels/compressible/EddyDiffusivity and there Prt is just set to 1.0 when not defined in your simulation constant/turbulenceProperties file. I think normally Prt is assumed to be 0.8 to 0.9like in: "ELEMENTS OF INDUSTRIAL HEAT TRANSFER PREDICTIONS " by Menter So do you also change Ptr or does everyone go with Ptr=1.0 because it is maybe not big of a deal? I changed it Code:
simulationType RAS; RAS { RASModel kOmegaSST; turbulence on; printCoeffs on; kOmegaSSTCoeffs { Prt 0.85; } } Last edited by superkelle; July 1, 2020 at 11:39. |
Agustín Villa
Rep Power: 15 ![]() |
Hi superkelle,
the turbulent Prandtl number is not an obvious question. It depends on the flow conditions rather than the fluid properties. It is usually set to 0.85-0.9-1 for Prandtl numbers close to 1 or above. At that stage this approach is a fair estimation. If you go for low Prandtl values, then this appraoch is not as valid as before. Using a larger Prt value (around 2) is the usual approach, but the turbulence modeling must be reconsidered. I hope it serves you for setting your Prt value! |
Thank you for your response. Is Prt a pure experimental to determin? I looked into different textbooks and they were all very quiet about Prt I only found the statement that it should be around 0.9 for air water like fluids , and for liquid metals at around 3. And also in OF tutorials Prt is very rarely set directly in RAS properties.
Agustín Villa
it is not present in some RANS properties as the few incompressible solvers that use it they define it at transportProperties. For compressible flows, as you're forced to solve the energy equation you must provide it at the RANS properties. The value you set depends on your application and working Pr value. You can have a guess with Prt=0.85 and then modify it if needed. You can check similar studies to yours to see what they propose for Prt. |
SimpleFoam & Theater | jipai | OpenFOAM Running, Solving & CFD | 3 | June 18, 2019 10:11 |
[Other] Equal decomposition of cylindrical fluid domain | Sean95 | OpenFOAM Meshing & Mesh Conversion | 3 | February 12, 2019 03:34 |
decomposePar -allRegions | stru | OpenFOAM Pre-Processing | 2 | August 25, 2015 03:58 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
