July 1, 2020, 10:45 |
Multiple solids
hamid
Rep Power: 5 |
Hi everybody,
I try to simulate a very basic steadystate solid heat transfer problem of two solids (cube) joined by a common surface. 1 - I created the mesh with gmsh which contains two volumes and i converted the msh file with gmshToFoam, so that it seems to geneate everything under constant/polyMesh 2 - I created two files : Constant\solid1\solidThermophysicalProperties Constant\solid2\solidThermophysicalProperties they contains a constSolidThermoCoeffs section with a K value. 3 - The two solids have different thermal conducitivties, as far as i understand laplacianFoam solver does not take in charge different values of conductivity, so i must use chtMultiRegionSimpleFoam solver. This solver indicates i need to have polymesh defined in each folder constant/solid1/2. I do not understand something cause constant/polymesh contains everything. 4 - If i defined two solids in Constant/regionProperties i get "fluid not found in table" Any help please... |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 04:17 |
[OpenFOAM.org] Install openFOAM 3.0.1 in Ubuntu 16.04 LTS from Deb packs | Pier84 | OpenFOAM Installation | 4 | June 18, 2016 16:22 |
[ICEM] part from ICEM to CFX multiple solids | Steffen595 | ANSYS Meshing & Geometry | 2 | May 20, 2016 18:48 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
