Prediction of outdoor temperature with OpenFOAM
Old   July 5, 2020, 05:49
Default Prediction of outdoor temperature with OpenFOAM
Singapore
bdgmm is on a distinguished road
Dear all,
To conduct urban microclimate and building energy studies, I developed a coupled scheme between OpenFOAM and EnergyPlus. The OpenFOAM model is in charge of assessing outdoor conditions (i.e. air motion and temperature) around a specific building at the urban microscale (i.e. with in a range of 1 km). For this purpose, I am using an incompressible solver: the buoyantBoussinesqSimpleFoam.
Currently, I am trying to compare estimates of the outdoor temperature with measurements. I find that the outdoor temperature provided by the OpenFOAM solver underestimates the measurements. I tried to increase the resolution of my meshing, but the underestimation even becomes larger. Somehow, I suspect that the heat transfer through the air is underestimated by the OpenFOAM solver. For instance, when I use the function wallHeatTransferCoeff to calculate the convective heat transfer coefficients, I obtain values between 0.01 and 0.5 W/m2-K while they should be above 5 W/m2-K.
The OpenFOAM documentation does not say much how the heat transfer or convective heat transfer coefficients are calculated by the buoyantBoussinesqSimpleFoam and integrated into energy conservation equation. Does anyone know how the heat transfer or convective heat transfer coefficients are calculated by the buoyantBoussinesqSimpleFoam solver? If yes, what would you recommend to improve the estimates of outdoor temperature with OpenFOAM when coupled with a building energy model?
Regards,
Miguel
bdgmm is offline   Reply With Quote
Old   July 5, 2020, 21:33
abdikerim kurbanaliev
kerim is on a distinguished road
bdgmm
Dear bdgmm,
It is very interesting research. Would you like to share with your case files?
Kerim
kerim is offline   Reply With Quote
Old   July 6, 2020, 02:10
Singapore
Hi Kerim,
Thank you very much for your post.
Unfortunately, I am not allowed to share the case files. I was just wondering whether someone in the CFD community has already tried to validate the outdoor temperature with one of the OF solvers.
I recently tried to get in touch with the OF support, but the do not provide any documentation about how the solvers evaluate the heat transfer or the convective heat transfer coefficient. From what I could experience, they seem to be underestimated.
Did you experience something similar in your study? The OF support told me that the buoyantBoussinesqSimpleFoam solver has been replaced by the more general buoyantSimpleFoam solver which can used be with the Boussinesq equation of state. Do you know how to do that?
Regards,
Miguel
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
Resistance prediction in shallow water using OpenFoam Zentari OpenFOAM Running, Solving & CFD 1 May 9, 2021 09:27
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 06:15
OpenFOAM Foundation releases OpenFOAM 2.2.2 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 October 14, 2013 07:18
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
