Turbine Siting - Changing Geometry
Old   March 15, 2014, 13:16
Default Turbine Siting - Changing Geometry
Andrew Mortimer
AndrewMortimer is on a distinguished road
I'm wondering if someone can give me a bit of help with some errors I'm getting.
I'm running the turbine siting tutorial with different geometry. So far I have changed the blockMeshDict and the snappyHexMeshDict to match the size of my new terrain.stl . I am getting errors though when solving it.
I have been using the ./Allrun script on 6 cores (4930k).
Below is the error I am getting out, not sure what is going wrong.
|  \\    /   O peration     | Version:  2.2.2                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.2.2-9240f8b967db
Exec   : simpleFoam -parallel
Date   : Mar 15 2014
Time   : 18:08:39
Host   : "andrew-pc"
PID    : 13373
Case   : /home/andrew/OpenFOAM/andrew-2.2.2/run/Dis/test_run
nProcs : 6
Slaves :
5
"andrew-pc.13374"
"andrew-pc.13375"
"andrew-pc.13376"
"andrew-pc.13377"
"andrew-pc.13378"
Pstream initialized with:
    floatTransfer      : 0
    nProcsSimpleSum    : 0
    commsType          : nonBlocking
    polling iterations : 0
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading field p
Reading field U
[0] #0  [3] #0  Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[3] #1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #2   in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[3] #2   in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #3  log in "/lib/x86_64-linux-gnu/libc.so.6"
[3] #3  log in "/lib/x86_64-linux-gnu/libm.so.6"
[0] #4  Foam::incompressible::atmBoundaryLayerInletVelocityFvPatchVectorField::atmBoundaryLayerInletVelocityFvPatchVectorField(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/lib/x86_64-linux-gnu/libm.so.6"
[3] #4  Foam::incompressible::atmBoundaryLayerInletVelocityFvPatchVectorField::atmBoundaryLayerInletVelocityFvPatchVectorField(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
[0] #5  Foam::fvPatchField<Foam::Vector<double> >::adddictionaryConstructorToTable<Foam::incompressible::atmBoundaryLayerInletVelocityFvPatchVectorField>::New(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
[3] #5  Foam::fvPatchField<Foam::Vector<double> >::adddictionaryConstructorToTable<Foam::incompressible::atmBoundaryLayerInletVelocityFvPatchVectorField>::New(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
[0] #6   in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
[3] #6  Foam::fvPatchField<Foam::Vector<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&)Foam::fvPatchField<Foam::Vector<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/simpleFoam"
[0] #7   in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/simpleFoam"
[3] #7  Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::readField(Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&)Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::readField(Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/simpleFoam"
[0] #8   in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/simpleFoam"
[3] #8  Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readFields(Foam::dictionary const&)Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readFields(Foam::dictionary const&) in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/simpleFoam"
[0] #9   in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/simpleFoam"
[3] #9  Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readFields()Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readFields() in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/simpleFoam"
[0] #10   in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/simpleFoam"
[3] #10  Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&)Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/simpleFoam"
[0] #11   in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/simpleFoam"
[3] #11
[0]  in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/simpleFoam"
[0] #12  __libc_start_main[3]  in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/simpleFoam"
[3] #12  __libc_start_main in  in "/lib/x86_64-linux-gnu/libc.so.6"
[3] #13  "/lib/x86_64-linux-gnu/libc.so.6"
[0] #13
[andrew-pc:13376] *** Process received signal ***
[andrew-pc:13376] Signal: Floating point exception (8)
[andrew-pc:13376] Signal code:  (-6)
[andrew-pc:13376] Failing at address: 0x3e800003440
[andrew-pc:13376] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7fb65a8314a0]
[andrew-pc:13376] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7fb65a831425]
[andrew-pc:13376] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7fb65a8314a0]
[andrew-pc:13376] [ 3] /lib/x86_64-linux-gnu/libm.so.6(log+0x24) [0x7fb65adf7544]
[andrew-pc:13376] [ 4] /opt/openfoam222/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so(_ZN4Foam14incompressible47atmBoundaryLayerInletVelocityFvPatchVectorFieldC2ERKNS_7fvPatchERKNS_16DimensionedFieldINS_6VectorIdEENS_7volMeshEEERKNS_10dictionaryE+0x87d) [0x7fb65e5120ed]
[andrew-pc:13376] [ 5] /opt/openfoam222/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so(_ZN4Foam12fvPatchFieldINS_6VectorIdEEE31adddictionaryConstructorToTableINS_14incompressible47atmBoundaryLayerInletVelocityFvPatchVectorFieldEE3NewERKNS_7fvPatchERKNS_16DimensionedFieldIS2_NS_7volMeshEEERKNS_10dictionaryE+0x47) [0x7fb65e513e17]
[andrew-pc:13376] [ 6] simpleFoam(_ZN4Foam12fvPatchFieldINS_6VectorIdEEE3NewERKNS_7fvPatchERKNS_16DimensionedFieldIS2_NS_7volMeshEEERKNS_10dictionaryE+0x336) [0x441216]
[andrew-pc:13376] [ 7] simpleFoam(_ZN4Foam14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEE22GeometricBoundaryField9readFieldERKNS_16DimensionedFieldIS2_S4_EERKNS_10dictionaryE+0x120) [0x44b6c0]
[andrew-pc:13376] [ 8] simpleFoam(_ZN4Foam14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEE10readFieldsERKNS_10dictionaryE+0x82) [0x44c2e2]
[andrew-pc:13376] [ 9] simpleFoam(_ZN4Foam14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEE10readFieldsEv+0xd6) [0x44c686]
[andrew-pc:13376] [10] simpleFoam(_ZN4Foam14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEC2ERKNS_8IOobjectERKNS_6fvMeshE+0x9c) [0x44c79c]
[andrew-pc:13376] [11] simpleFoam() [0x418c54]
[andrew-pc:13376] [12] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7fb65a81c76d]
[andrew-pc:13376] [13] simpleFoam() [0x41b71d]
[andrew-pc:13376] *** End of error message ***
[andrew-pc:13373] *** Process received signal ***
[andrew-pc:13373] Signal: Floating point exception (8)
[andrew-pc:13373] Signal code:  (-6)
[andrew-pc:13373] Failing at address: 0x3e80000343d
[andrew-pc:13373] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7f90267174a0]
[andrew-pc:13373] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7f9026717425]
[andrew-pc:13373] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7f90267174a0]
[andrew-pc:13373] [ 3] /lib/x86_64-linux-gnu/libm.so.6(log+0x24) [0x7f9026cdd544]
[andrew-pc:13373] [ 4] /opt/openfoam222/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so(_ZN4Foam14incompressible47atmBoundaryLayerInletVelocityFvPatchVectorFieldC2ERKNS_7fvPatchERKNS_16DimensionedFieldINS_6VectorIdEENS_7volMeshEEERKNS_10dictionaryE+0x87d) [0x7f902a3f80ed]
[andrew-pc:13373] [ 5] /opt/openfoam222/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so(_ZN4Foam12fvPatchFieldINS_6VectorIdEEE31adddictionaryConstructorToTableINS_14incompressible47atmBoundaryLayerInletVelocityFvPatchVectorFieldEE3NewERKNS_7fvPatchERKNS_16DimensionedFieldIS2_NS_7volMeshEEERKNS_10dictionaryE+0x47) [0x7f902a3f9e17]
[andrew-pc:13373] [ 6] simpleFoam(_ZN4Foam12fvPatchFieldINS_6VectorIdEEE3NewERKNS_7fvPatchERKNS_16DimensionedFieldIS2_NS_7volMeshEEERKNS_10dictionaryE+0x336) [0x441216]
[andrew-pc:13373] [ 7] simpleFoam(_ZN4Foam14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEE22GeometricBoundaryField9readFieldERKNS_16DimensionedFieldIS2_S4_EERKNS_10dictionaryE+0x120) [0x44b6c0]
[andrew-pc:13373] [ 8] simpleFoam(_ZN4Foam14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEE10readFieldsERKNS_10dictionaryE+0x82) [0x44c2e2]
[andrew-pc:13373] [ 9] simpleFoam(_ZN4Foam14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEE10readFieldsEv+0xd6) [0x44c686]
[andrew-pc:13373] [10] simpleFoam(_ZN4Foam14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEC2ERKNS_8IOobjectERKNS_6fvMeshE+0x9c) [0x44c79c]
[andrew-pc:13373] [11] simpleFoam() [0x418c54]
[andrew-pc:13373] [12] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f902670276d]
[andrew-pc:13373] [13] simpleFoam() [0x41b71d]
[andrew-pc:13373] *** End of error message ***
mpirun noticed that process rank 0 with PID 13373 on node andrew-pc exited on signal 8 (Floating point exception).
Any help would be greatly appreciated.
Cheers!
AndrewMortimer is offline   Reply With Quote
Old   March 18, 2014, 12:26
Pete Bachant
pbachant is on a distinguished road
How is the mesh? Have you run checkMesh? Also, are the searchableBoxes for the actuator disks moved to the correct locations in the domain?
pbachant is offline   Reply With Quote
Old   July 11, 2020, 10:07
Default Turbine Siting Tutorial OpenFOAM
Hrishikesh
hrishikeshsivanandan is on a distinguished road
Is there a tutorial online which can give a step by step implementation of the TurbineSiting tutorial? I am new to OpenFOAM and need a detailed explanation of the TurbineSiting tutorial. Anyone willing to point me in the right direction?
hrishikeshsivanandan is offline   Reply With Quote
siting, solving, turbine, tutorial
Problem with torque output from a turbine simulation. pa-dundas FLUENT 5 July 17, 2022 05:27
CFD analysis on wind turbine rotor Ken (Wind Turbine CFD Super Rookie) Main CFD Forum 45 February 9, 2016 14:07
Wind turbine GEOMETRY James Hetfield Main CFD Forum 2 November 1, 2011 01:09
Wind turbine GEOMETRY James Hetfield FLUENT 0 October 31, 2011 19:12
changing geometry yann Siemens 7 February 17, 2006 05:40
