spurious velocities with icoReactingMultiphaseInterFoam due to high surface tension
Like Tree1Likes
  • 1 Post By navidamin
Old   December 26, 2020, 06:07
Default spurious velocities with icoReactingMultiphaseInterFoam due to high surface tension
flo(w) is on a distinguished road
Dear all, I'm using the icoReactingMultiphaseInterFoam solver to simulate the laser melting process. I have 3 components: Solid, liquid and gas. Everything works well as long as the surface tension is as low as 0.07 N/m. But spurious velocities occur and the simulation blows up, when I increase the surface tension to the physically correct value of 1.7 N/m, which is a typical value for liquid metals. It seems as if the spurious velocities occur in the area of the interface between gas and liquid/solid where melting or solidification takes place.
Can anyone give me a hint how to solve the problem? Many thanks!
flo(w) is offline   Reply With Quote
Old   March 4, 2021, 05:56
Navid
navidamin is on a distinguished road
Well, it depends on your case characteristics. If you have a melt and solid, it means you have temperature gradient in your melt flow and thus you need to take care of marangoni force. in most cases , Maranogni compensates for the effects of surface tension force to some extent and thus alleviates the unwanted spurious currents at the surface, to a good degree.
Juan Daniel likes this.
navidamin is offline   Reply With Quote
VOF +surface tension force modeling+ open channel flow+cyclic region= fatal error? SJSW Fluent Multiphase 2 November 18, 2014 04:15
Surface tension - normal or tangential ? manxu Main CFD Forum 5 October 23, 2013 12:39
Surface Tension Test Cases sega OpenFOAM Running, Solving & CFD 2 March 8, 2011 12:19
Surface Tension Gradient Alisher FLUENT 0 March 26, 2008 04:26
surface tension model in EX26 Junhua Wu FLUENT 0 June 7, 2000 10:49
