Error while running compressibleInterFoam (Possibly because of wrong T BC) |
August 26, 2020, 06:05 |
Prasad ADHAV
Rep Power: 6 |
Here are my details about my system: Kubuntu 18.04LTS OpenFoam v7 Case set up: I am trying to run a LES-VOF simulation for waterjet in an AWJC Nozzle, where the water jet velocity is 300m/s. The phases are air and water. I have successfully run a simulation with interFoam (incompressible case). I want to run a compressible simulation for the same case set up. I took the thermophysicalProperties, thermophysicalProperties.air and thermophysicalProperties.water from sloshing tank tutorial case. I replicated p_rgh to p and added a T file sine there was none in the interFoam case. The T file is as follows: Code:
FoamFile { version 2.0; format ascii; class volScalarField; object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 1 0 0 0]; internalField uniform 300; boundaryField { wall { type fixedValue; value uniform 300; } inlet { type fixedValue; value uniform 300; } inlet2 { type fixedValue; value uniform 300; } inlet3 { type fixedValue; value uniform 300; } outlet { type fixedValue; value uniform 300; } } Here is the error: Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 7-1ff648926f77 Exec : compressibleInterFoam Date : Aug 26 2020 Time : 11:35:03 Host : "XDEM-laptop" PID : 17318 I/O : uncollated Case : /home/prasad/01_PhD/3_Tutorials/3_trials/0_Nozzle_OF/Turb_1_300ms-1_compressibleInterFoam nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Selecting dynamicFvMesh staticFvMesh PIMPLE: No convergence criteria found PIMPLE: Operating solver in transient mode with 1 outer corrector PIMPLE: Operating solver in PISO mode Reading field p_rgh Reading field U Reading/calculating face flux field phi Constructing twoPhaseMixtureThermo Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo eConst; equationOfState perfectFluid; specie specie; energy sensibleInternalEnergy; } Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::heThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::heThermo(Foam::fvMesh const&, Foam::word const&) at ??:? #4 Foam::rhoThermo::addfvMeshConstructorToTable<Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > > >::New(Foam::fvMesh const&, Foam::word const&) at ??:? #5 Foam::autoPtr<Foam::rhoThermo> Foam::basicThermo::New<Foam::rhoThermo>(Foam::fvMesh const&, Foam::word const&) at ??:? #6 Foam::rhoThermo::New(Foam::fvMesh const&, Foam::word const&) at ??:? #7 Foam::twoPhaseMixtureThermo::twoPhaseMixtureThermo(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:? #8 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/compressibleInterFoam" #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/compressibleInterFoam" Floating point exception (core dumped) I need suggestions. Please let me know if I should share anything else. Thank you in advance. |
Error when running pimpleFoam: wrong token type -expected Scalar ... 'nan' | khronno | OpenFOAM Running, Solving & CFD | 7 | February 19, 2024 01:31 |
[solids4Foam] HronTurekFsi3 Laminar Tutorial not running parallel using Foam-Extend 4.1? | EternalSeekerX | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 0 | May 29, 2020 03:12 |
Self-Bailer Analysis Cd possibly wrong?? | Armitage | ANSYS | 0 | April 28, 2019 06:05 |
Wrong results from motorByke tutorial in OpenFoam 2.1.1 | jsc | OpenFOAM Running, Solving & CFD | 3 | April 16, 2013 07:26 |
star is not running the simulation in windows | Arnab | Siemens | 1 | August 2, 2004 02:40 |
